Clone Goldmund Amplifier
Old 16th December 2011, 03:57 PM   #141
hien.t.nguyen is offline hien.t.nguyen
hien.t.nguyen's Avatar
Send a message via Yahoo to hien.t.nguyen Clone Goldmund Amplifier
C18,C73 not found on the circuit diagram but it have in the part list,it might be option
C18,C73: 100nF/100V MKS2 Wima
Ultraline1@gmail.com
Old 16th December 2011, 04:24 PM   #142
tommy1000 is offline tommy1000  Denmark
Is C65, and C24 missing also?
Old 16th December 2011, 04:34 PM   #143
Well,sorry
C65,C73 is bypass capacitor for Vcc(power)
I am not found C18,C24 on schematic Metis3
Old 16th December 2011, 04:43 PM   #144
Thank you.
Old 27th December 2011, 08:57 AM   #145
Default The new vesion
The new vesion of the clone Goldmund Amplifier,today I re-layout with dual channel versions.
Original metis 3 circuit(#390.2)
All in one,dual chanel,very compact, using SMD components, ... compatible with heatsink have the length > 16cm(heasink in picture my layout is 19cm)
Appropriate for many types of chassis.
Happy New Year
Regards.
Old 27th December 2011, 09:02 AM   #146
Schematic used for this layout.
Old 27th December 2011, 09:38 AM   #147
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Very appealing PCB, it's just that I don't like this kind of output BJT assembly, it is self limiting and has good thermal spreading only in installation you've suggested. PSU part has only 3200uF per rail, this is not nearly sufficient for two pairs of outputs per channel. 32000uF sounds more adequate ...
Old 27th December 2011, 09:52 AM   #148
thank for your comments.
Hix,this is the original circuit
I've said in the topic"The Very Best Amplifier I Have Ever Heard!!!! "
Have two ways to have great sound with Goldmund circuit(lateral mosfet output) is:
1. High current bias(200-300mA), with power supply enough clean (large capacitance>10.000uF or parallel multiple small capacitors),it raises more heat,heatsink must be large enough.Goldmund does not choose.
2. Low current bias(70-90mA), the power supply does not need too clean(for Power Amplifier stage - Output).Goldmund has chosen this option,so they just choose capacitors for the power supply is 2200uF +1000uF = 3300uF.Their heatsink is very small.
Because the small capacitance means is the impedance power supply will be greater,it raises many harmonic distortion on the load speakers, when considering the load resistor to announce the results, it is very low harmonic distortion but the reality is not so, the speaker is not the same as resistance.
Sounds great,to less expensive materials,structure machine not bulky,be durable by very low-temperature,little damage, very aesthetic,...
Regards.
Old 27th December 2011, 10:05 AM   #149
Lazy Cat's Avatar
OK, maybe appropriate SMPS would do much better than this but anyway I like the channel schematic, especially double input fet.
One day I'll do the amp involving this one or LS5912 from Linear Systems.
P.S. BTW 2200+1000=3200
Old 27th December 2011, 10:10 AM   #150
P.S. BTW 2200 + 1000=3200
Ok,maybe you're right
Clone Goldmund AmplifierHide this!Advertise here!
Goldmund Mimesis 3 Clone, World's Best Amplifier!!!! NagysAudio Solid State 128 8th December 2010 07:30 AM
Goldmund lumanauw Solid State 32 26th January 2006 04:08 PM
Proac 2.5 clone, what Amplifier kevinkuang Multi-Way 20 17th March 2005 12:21 AM
Goldmund Speakers audioPT Multi-Way 0 11th September 2002 09:52 AM
