#121 |
#122 | |
Pc on the NPN : Pc= 4.46mA x 140V = 624mW # Pc max MPSA42/92. Very easy to fire, explosion
Ultraline1@gmail.com |
#123 |
This is Rload line of 2N5565 in 3 cases T5000,M3,M330.
M330 is almost less than linear the 2 cases other.
Ultraline1@gmail.com Last edited by hien.t.nguyen; 15th December 2011 at 05:58 AM. |
#124 |
I always support you, so sorry that you are not active in the VNAV forums, I don't know anything was done in your problem , but I always support you .
Try to up . i'm a fan of you . |
#125 |
Can you show where in the schematic this problem can be found?
#126 | |
I have problem not fun in there,I do not want to contribute more posts there. Well, do not dilute the topic, if you have any questions for technical of Goldmund myclone,you can ask me in here. Regards,
#127 | |
Q26=on => Vce(Q26)#0V Vce(Q29) = 2xVcc = 140V while the current of Q29 is 4.66mA => Pc (Q29) = 624mW
#128 |
How do the load line in post123 fit with the data in the recent posts?
We are discussing BJTs and yet post123 is clearly referring to FETs. The upper limit of the posted load line graph is 20Vds. How does that relate to the 70Vce and 140Vce that you are stating? |
#129 |
Mr. Hien, so sorry for your problem in vnav.
![]() I'm want to ask you few questions. Why in your schematic, between post #25 and schematic in post #100 have a difference? In post #25 gate resistors of power mosfet connect different gate resistors in post #100. What's right? |
#130 | |
(3W) total power. But only if coold off by the PCB, see picture. You can not replace this part with one MPSA92. (it will get too hot) But the MM9.2 and the chinese clone uses one MPSA92 in this position. That's why goldmund changed to FZT in later models. |
| Goldmund Mimesis 3 Clone, World's Best Amplifier!!!! | NagysAudio | Solid State | 128 | 8th December 2010 07:30 AM |
| Goldmund | lumanauw | Solid State | 32 | 26th January 2006 04:08 PM |
| Proac 2.5 clone, what Amplifier | kevinkuang | Multi-Way | 20 | 17th March 2005 12:21 AM |
| Goldmund Speakers | audioPT | Multi-Way | 0 | 11th September 2002 09:52 AM |
