Old 13th December 2011, 03:09 PM   #101
hien.t.nguyen's Avatar
Send a message via Yahoo to hien.t.nguyen Send a message via Skype™ to hien.t.nguyen
values on the gate resistors: 820 ohm for N channel and 470 ohm for P channel with lateral mosfet is 10N20+10P20
Ultraline1@gmail.com
Old 13th December 2011, 03:32 PM   #102
which class this amp working on?
only high power ? quality? distortion?noisy? bandwith?...
Old 13th December 2011, 04:15 PM   #103
Original Metic 3 used driver MJE340+350
Old 13th December 2011, 04:28 PM   #104
Amplifier working in class AB
Harmonic Distortion < 0.001%
Noise 116dB with intergrated amplifier
Noise 122dB with power amplifier
bandwith
10Hz-70Khz: +/-0.1dB
1Hz-200khZ: +/-1dB
capacity depends on model myclone
Old 13th December 2011, 05:08 PM   #105
Wow look what turns up after four months! Thank you!
Can you show us the input stage also?
I think that the CCS is different from the MM9.2?
And one OPA134?
Old 13th December 2011, 05:17 PM   #106
Yes,i can
CCS used ZTX694B
Old 13th December 2011, 05:25 PM   #107
Your picture is this chanel,i see R72,C31 in the your picture
Old 13th December 2011, 05:33 PM   #108
Any change in this parts?
Old 13th December 2011, 05:39 PM   #109
And one OPA134?
Can you show more pictures? i want to see layout original
Old 13th December 2011, 05:45 PM   #110
OK,it is R56 = 33K and R62 = 10K => Vb = (10/43)xVcc
Your post #108 is schematic Goldmund module job4,it used 56K and 33K,lateral mosfet output is K1058+J162,I have also this schematic but I dont know it use in what model Goldmund?
Goldmund Mimesis 3 Clone, World's Best Amplifier!!!! NagysAudio Solid State 128 8th December 2010 07:30 AM
Goldmund lumanauw Solid State 32 26th January 2006 04:08 PM
Proac 2.5 clone, what Amplifier kevinkuang Multi-Way 20 17th March 2005 12:21 AM
Goldmund Speakers audioPT Multi-Way 0 11th September 2002 09:52 AM
Copyright ©1999-2013 diyAudio
