Here is what is basically a Taylor half-diamond follower, but with a twist: Q4 and Q5 take care of the positive part of the signal, ensuring symetrical performance, and smooth class B operation: |
#2 |
Holding the input constant what is the worst case oamffset (drift)?
It does look like a novel idea. Jam |
#3 |
In this example, it is approximately 50mV (Q1 and Q3 held at the same temperature).
It depends on the matching of the current densities in Q1 and Q3. If the currents are scaled in the same proportion as the junction areas, a first order cancellation occurs, both statically and dynamically. |
#4 |
Brilliant, Elvee!
Have you built and auditioned it? Hugh |
#5 |
Yes, I have built it, tested it with real audio too: no obvious flaw.
I won't comment further in that direction since I have tin ears, but it sounds OK. It is not a topology for the faint hearted though: the input impedance is negative, which can be disconcerting to the novice.
#6 |
You know the base current of 2n3055 is wildly not a linear load.
Somehow need to add or subtract that drive current back into the equation that will hold Q1's emitter drop constant. |
#7 |
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#8 |
Easier way to hold half diamond emitters at constant voltage drop...
Taylor still worth knowing, please keep exploring the original circuit. |
#9 |
Or this way too, could hold those two emitters constant.
You might ask, why not a simple mirror across the top? Yeah, but a mirror isn't so easy to bootstrap. Or is it??? M2 might want gate swing a few volts above the rail. I keep trying to throw a gratuitous Taylor in there, other weird solutions just keep popping in my head. At least we are watching a collector and bouncing that info as current to an active load on the emitter... Last edited by kenpeter; 19th September 2011 at 01:05 AM. |
| the Double Diamond VAS | Stee | Solid State | 4 | 9th January 2010 03:07 PM |
| DC adjustable double-Sziklai Power Diamond Buffer | mtlin12 | Solid State | 22 | 16th July 2005 06:11 AM |
| Page generated in 0.18966 seconds (48.97% PHP - 51.03% MySQL) with 11 queries |
