DIAMOND DIFFERENTIAL INPUT POWER AMPLIFIER EBay kit DIAMOND DIFFERENTIAL INPUT POWER AMPLIFIER EBay kit - Page 2 - diyAudio
Old 16th March 2011, 08:14 AM   #11
dinamic1 is offline dinamic1
Has someone finished this amp? l would like to share experiences on buildind this..l have the impression this will not work :-)
Old 16th March 2011, 08:15 AM   #12
poler is offline poler  United States
i'm curious as well
Old 16th March 2011, 09:50 AM   #13
janusz is offline janusz  Australia
Which amp are you referring to? The kit from tubeshunter/jims audio or Sansui or ...?
The board version I got is 1.4. Tubeshunter sold 12 of these so far going back to November.
cheers,
Old 16th March 2011, 10:10 AM   #14
Mine is from tubeshunter..v1.4..have you some documentation from the seller? l donīt receive it wiht the kit..incomplete parts too :-( ..can somebody help me?
Old 16th March 2011, 07:15 PM   #15
the kit of course, so did you finish it ? how does it sound?
Old 16th March 2011, 08:41 PM   #16
No, l had not finished yet....
Old 16th March 2011, 08:42 PM   #17
Sorry I meant it for Janusz
Old 17th March 2011, 12:35 AM   #18
dinamic1,
My kit came with no notes whatsoever so I wrote to tubeshunter. Below in PS is his response. I have downloaded both circuit diagrams from these addresses.
I haven't built the kit yet. I've asked a friend of mine to run simulation of this amp and this morning I got his reply. It's not a stunning amp like Stochino but pretty good. It's sensitive to the quality of PS. Consequently, I will use regulated PS +/-58V for the voltage stage and double bridge +/-55V for the output.
At 1W THD is 0.000362
h2 = -126dB, h3 =-113dB
R21 must be 220ohm while the simulation showed that zero offset was achieved with R16=195 ohm. It may be better then to leave R28 and W2 in the circuit and preset R16, R28 and W2 to give 195 ohm. When hot one may need to adjust that setting a touch.
cheers,
PS
Dear pradzyndaria,
Hi! 45V-0V-45V power transformer is OK unless you upgrade the voltage rating of some capacitors to 80VDC.
Circuit diagram (Power amp):
http://www.pix8.net/pro/pic.php?u=14821Z2xl&i=11562079
Circuit diagram (speaker protection):
http://www.pix8.net/pro/pic.php?u=14821Z2xl&i=11562080
Note:
1. W2 - omitted
2. "***" = 220 ohm
Adjustment:
1. Apply power but do not install power outputtransistors in this moment, adjust W1 to make 1K (FET drain resistor) to 2.3---2.6VDC
2. Adjust W3 to set the voltage difference between pin 1 & 3 of power output transistor to 0.45V or less. Do not install power output transistor in this moment too!
3. Test the DC offset. Install the power output transistors in case of the output DC offset is 25mV or less. Otherwise check! Adjust W3 and check the voltage drop of 0.22 ohm / 5W resistor. 10mV to 40mV (depends on effiency of the heatsinks) is ideal volatge drop.
- tubeshunter
Old 17th March 2011, 07:24 AM   #19
Thank you janusz for that information...līll try to finish the amp...
Old 17th March 2011, 12:18 PM   #20
forr is offline forr  France
forr's Avatar
Hi Janusz,
Thanks for showing a more recent Diamond Sansui circuit than mine.
However I think it was fatal to Sansui, because in search of having a very high slew rate and low distorsion, Sansui compromised the feedback stability and its high power amps using this circuits were not reliable.
A pity that Sansui does not exist anymore, because I very much like its products.
DIAMOND DIFFERENTIAL INPUT POWER AMPLIFIER EBay kitHide this!Advertise here!
FS: F5 Amplifier Kit - Boards, Heatinks, Power Caps, Input Caps, RCAs, Binding Posts gripracer Swap Meet 17 6th November 2013 02:28 PM
Sansui Diamond-Differential with current mirror loads and self biased VAS cascodes steph_tsf Solid State 10 15th July 2013 05:29 AM
"An Adjustment-Free Complementary Power Amplifier" by J.Diamond jez Solid State 28 22nd August 2010 11:33 PM
eBay TDA7294 kit + Parts Express Buyout 32V CT 200VA Toroidal Power Transformer? IsleOfMan Chip Amps 7 19th February 2009 08:44 AM
Copyright ©1999-2017 diyAudio
