MJL1302 and MJL3281 best driver transistors MJL1302 and MJL3281 best driver transistors - Page 3 - diyAudio
Old 28th December 2012, 11:44 PM   #21
Dave Zan is offline Dave Zan  Australia
Originally Posted by Stormrider View Post
2sa1930/2sc5171 are a good choice for medium power amps if you can get them.
For really high power uses the OnSemi MJE15034/35 devices work, but they are not in the same class as the 1302/3281's.
Yes. It is a pity that there is not a driver to really match the 1302/3281.
The 1930/5171 enter second breakdown too early for my plans.
Has anyone considered a FET as a driver? Seems like it may be a suitable application.
Best wishes
David
Old 29th December 2012, 12:35 AM   #22
Andrew Eckhardt is offline Andrew Eckhardt  United States
2sk216 and 2sj79 were great sounding drivers in front of those, back in the '90s..
Old 29th December 2012, 01:15 AM   #23
These folks seem to understand lateral power FETs for audio. Wonder why they don't release a 1 Amp driver and become the go-to source:
Magnatec. ALFET Lateral MOSFETs
They don't care about your bipolar driving problems? Their 8 Amp model doesn't get linear until too high current, and has 600p input capacitance compared to 90 for the old Hitachi parts...
Old 29th December 2012, 02:59 PM   #24
Telstar is offline Telstar  Italy
Hitachi lateral mosfets are excellent drivers. Hard to source, though.
I saw more than one amp using the same 1302/3281 as drivers, amd then using predrivers. This with several output pairs. If you have 4 tops, it's not needed.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 29th December 2012, 09:15 PM   #25
I am interested in the potential speed of MOSFETs for use in advanced compensation schemes. So the laterals are less attractive to me, no real improvement on the 15034/35 which is my current benchmark.
Some of the verticals have ~100pF. I am not very familiar with FETs but total (gate stopper + intrinsic) resistance of 10 ohms looks reasonable so roll-off around 160 MHz, a substantial jump from the 15034/35.
Best wishes
David
Old 29th December 2012, 10:28 PM   #26
Ian Finch is offline Ian Finch  Australia
Originally Posted by Andrew Eckhardt View Post
...... Wonder why they don't release a 1 Amp driver and become the go-to source:
The product is SEMELAB who also do a nice line of audio power transistors. Profusion handle the same LATFET parts with different marking and more - They are probably the "go-to" source now.
Medium Power-Driver
Ian
Old 29th December 2012, 11:11 PM   #27
Originally Posted by fab View Post
....I could not find the option to select the "E" suffix for 100 to 200 HFE range....Fab
Sadly, this option for through-hole parts is disappearing too. Even JFETs have almost vanished since Fairchild cut production of many US types. I can only suggest buying stocks to last into the forseeable future, if they become available as this is a sure sign of obsolescence. I really don't like the option of building anything new based on NOS or high-risk fake parts.
I have to sort my low-med power transistors for Hfe now too. That's why the parts selected must be cheap and designs need to be centred on the available range. However, I don't think you will have problems getting a good yield with 100-200 spec.
Ian
Old 30th December 2012, 02:12 AM   #28
fab is offline fab  Canada
fab's Avatar
Medium Power-Driver
Thanks for the link to Profusion. However,the web site states : "For a lateral MOSFET amplifier you are better served with Sanyo's 2SA1209/2SC2911. Why? The low output capacitance (Cob) of these devices translates to reduced "Miller" effect, resulting in lower distortion..."
But the table of transistor provided does not include the 2SA1209/2SC2911 nor using the search engine...
Fab
Old 30th December 2012, 08:59 AM   #29
tommy1000 is offline tommy1000  Denmark
OnSemiconductor owns Sanyo Semiconductor now and the 2SA1209/2SC2911 is EOL:
ON Semiconductor (some stock)
ON Semiconductor
Old 30th December 2012, 11:04 PM   #30
LineSource is offline LineSource  United States
LineSource's Avatar
I favor building a ROBUST solid state amp that will not self-destruct with a 1-ohm load. I make sure that no transistor exceeds its spec's with a 1-ohm load in both Spice and on-bench testing.
Triple T Class-AB with low Class-A bias Output Stage:
--- output: NJL3281D NPN, NJL1302D PNP
--- driver: MJE15034 NPN, MJE15035 PNP -- do not destruct with 1 ohm load
--- VAS Hawksford Enhanced Cascode or standard Cascode: Low Voltage High Beta signal driver BC560C or 2SA970 PNP, BC550C or 2SC970 NPN. High Voltage Cascode 2SC3503 NPN and 2SA1381 PNP
I want to protect my speakers over my amplifier. Instead of putting a SPEAKER-CONNECT-RELAY in series between the amp output stage and speakers I have my "safe operation" protection circuits control a LARGE MOSFET with a 1ohm shunt resistor connected to the amp output terminals. If DC is detected, or if the output signal does not closely follow the input signal the MOSFET+1ohm is shunt connected and AC power disconnected to protect the speakers.
Save the Planet! Go Green! For low Class-A bias with Class-AB Output Stages I favor using ThermalTrak NJL3281D (NPN) and NJL1302D (PNP). The thermal diode really does reduce thermal transient distortion, especially for the first 30 minutes after turn-on.
For high Class-A bias, high power Class-AB amps with many output transistors pairs where fast Vbe thermal transisents do not occur the Sanken NPN 2SA1216 and Sanken PNP 2SC2922 have superior sound and thermals.
MJL1302 and MJL3281 best driver transistorsHide this!Advertise here!
MJL3281 / MJW3281 differences? gmikol Solid State 4 5th April 2008 04:39 PM
Driver Transistors Bigred Parts 5 31st January 2008 04:35 AM
Mjl3281 Soar Pingrs Solid State 7 9th March 2007 12:47 PM
wanted :MJL1302/3281 flatpack pinkmouse Swap Meet 5 4th December 2006 08:38 AM
MJL3281/1302 pinkmouse Parts 8 6th June 2003 05:31 PM
Copyright ©1999-2017 diyAudio
