LINEUP Input-VAS, idea - Page 6 - diyAudio
Old 14th March 2011, 09:11 PM   #51
My FB is AC coupled??? When did that happen?
You mean #37?
As long as NJFET pair matches and drifts together, and PJFET pair matches and drifts together,
NJFETs do not require close match to PJFETs.
Old 14th March 2011, 09:59 PM   #52
Hi Lineup!
Please comment:
Hi Lineup!
As far as I can see, you wont get double gain by using complement pairs. Look at it this way: One transistor will need a certain drive to pass a certain current. The other transistor will need an equal amount of drive just to pass the same current. ( which it will have to , since they are in series. ) So you will get the same gain as with only one transistor ( your example one ).
You might get some linearization of the FETs though.
Thorsten Larsen
Old 14th March 2011, 10:18 PM   #53
True, drive voltage double is canceled when transconductance is halved.
I still think this plan is superior for PSRR. Differentially driven with most
power noise cancelled in the common mode. In the VAS itself, a high Z
drain or collector points at rail noise, rather than low Z source or emitter.
I don't see how the JFET is linearised? (current or voltage linearity?)
Expending gain to linearize current would be working directly against
the objective of a linear voltage amplifier. Only care transconductance,
and the direct coupled local loop makes voltage linearity.
Take away all feedback that "linearizes" the FET in the current domain,
and the voltage domain distortion of the loop goes down -10db.
Try to have it both ways at once, you get a tube amp that might sound
nice, but isn't necessarily linear in either domain.
Old 14th March 2011, 10:40 PM   #54
artu is offline artu  Chile
artu's Avatar
Kenpeter :
You mean #37?
Yes #37, C1 (100uF) that's AC coupling, R13 connected to 0V directly is DC coupling, not the case shown in #37
Cheers
Arturo
Old 14th March 2011, 10:53 PM   #55
#37 has plenty other problems not worth the low offset.
Not relevant here, except how the biasing trick proved graftable to Lineup's circuit.
Old 14th March 2011, 11:15 PM   #56
artu's Avatar
Anyway, with or without the biasing trick, if direct coupled (as it is lineup's circuit) it will have much more thermal drift than AC coupled FB loop, maybe you will need a DC servo ... new problems, among others is the clipping asymmetry at low freq. <100HZ, and the stored charge at the integrator = slow response.
Old 14th March 2011, 11:47 PM   #57
I am still not seeing where this thermally drifted DC offset happens?
The input compares to the output, and matched parts thermally bonded have the same drift...
Again, N's don't have to match or drift with the P's. But the input side does have to match
and drift with the feedback side. Why is this circuit causing you to worry so much more on
drift than another with the same matched and bonded component pairs at the input?
Old 15th March 2011, 12:33 AM   #58
artu's Avatar
Things in reality are much more complex, the theory takes account on what 'should' happen given a hypothetical math. perfect model and other unrealistic assumptions (the ideal OP amp, infinite input impedance, zero output impedance, infinite OLG) , physical real devices departs slightly but enough from theory, to make arise all this effects, that's why nowadays chip makers uses some built-in mechanism to address this issue. I have experienced at simm's and in practice (there are some topologies more or less prone to drift, other discussion). Do some temp. (30-100) simm's and you'll verify that in a DC FB loop this drift could be as high +/-100mV or more. Maybe a +/- 30mV drift is OK for a power amp, but not for a headphone amp, that's my point.
Cheers
Arturo
Discrete Regulator for VAS and Input Stage Havenwood Power Supplies 14 16th September 2010 05:28 PM
input stage and VAS testing gain Solid State 9 25th October 2008 10:27 PM
Idea for linearizing a cascoded VAS ionomolo Solid State 9 27th June 2008 09:44 PM
Help designing Input and Vas stage's DoomPixie Solid State 28 13th January 2006 10:28 PM
Copyright 1999-2017 diyAudio
