Old 9th March 2011, 12:13 PM   #11
ontoaba is offline ontoaba  Indonesia
ontoaba's Avatar
For better thermal, R8, R9, R10 could be split into four. See my failed VL83 schematic that I posted about few month ago at "Its 2010 what your favourite VAS" or something like that, also attached at my VL85 cheapamp my lonely thread.
The center pic at first post VAS is very good and very low gain if Re is split into two with input from center. For facing my crazy supply ripple, using crossed current feedback input with only 1.6x gain, it work great.
Old 11th March 2011, 10:59 AM   #12
lineup is offline lineup  Sweden
lineup's Avatar
Default ALL JFET Example
A nice example. All JFET.
All 2SK170BL, 2SJ74BL runs 6 mA. Output single end, too.
Gain is 1 = follower.
Level for test is +/-4 Vpeak, 1 kHz.
All 4 JFET in VAS runs with 12 Volt across each.
THD is very low.
2nd at -131dB
3rd at -138dB
4 caps for compensation gives a nice AC analysis.
See image 2.
-3dB at around 5 MHz
Enjoy
lineup
Old 11th March 2011, 11:31 AM   #13
destroyer X's Avatar
Default This is the main problem of these things...looks good and simulates good
But will they sound fine?.... only building to listen and compare to a reference and test it using non biased evaluators.
Looks great..no doubts....but there's a lot of things that looks great but are not great.... sometimes sound ordinary as Hugh told.... well..he can say things about as he built.
regards,
Carlos
Dx Super A - Brazil - Layout Zimmer; http://www.youtube.com/watch?v=yxpYnUA6Bj0
Old 11th March 2011, 11:51 AM   #14
What exactly was the purpose of redundant stage U1(Active)-U2(CCS)?
Weren't U4(Active)-U5(Active) already able to swing twice that much current?
Old 11th March 2011, 12:12 PM   #15
Electrons are yellow and more is better!
peranders's Avatar
The stage is an output buffer. U4, U5 has a very high output impedance. U1 and U2 are both essential here.
/Per-Anders (my first name) or P-A as my friends call me
Tube Buffered Gainclone in work |Thread
Old 11th March 2011, 09:29 PM   #16
MiiB is offline MiiB  Denmark
Can it work floting in the center like that...??
Old 11th March 2011, 10:24 PM   #17
Hi Lineup!
As far as I can see, you wont get double gain by using complement pairs. Look at it this way: One transistor will need a certain drive to pass a certain current. The other transistor will need an equal amount of drive just to pass the same current. ( which it will have to , since they are in series. )
You might get some linearization of the FETs though.
Thorsten Larsen
Old 12th March 2011, 12:17 AM   #18
U4, U5 has very LOW output impedance if you were to close the loop here.
And twice the potential current swing into a real load as U1 + CCS.
U1 and U2 are absolutely redundant and non-essential if they aren't going
to slew any more current than the stage that drives them.
Old 12th March 2011, 01:10 AM   #19
artu is offline artu  Chile
artu's Avatar
Default Here I am with peranders
I don't agree, if you do so, you will degrade OLG, rise the output impedance and rise the distortion significantly. With the same OPS, slew depends to a great extent on how weak or hard is the drive, that means how high or low is the output impedance of the driver.
Cheers
Arturo
Old 12th March 2011, 02:39 AM   #20
OLG (voltage) is not increased by a source follower. Go figure...
And unfortunately neither is this specific example giving us any
current gain...
I agree about slew, thats why the driver stage is better here:
His output stage abusing same JFET at exactly same current.
Yet pulling SE against fixed CCS, is only half as capable as the
push-pull circuit that is driving it. Defeats its own purpose...
Discrete Regulator for VAS and Input Stage Havenwood Power Supplies 14 16th September 2010 04:28 PM
input stage and VAS testing gain Solid State 9 25th October 2008 09:27 PM
Idea for linearizing a cascoded VAS ionomolo Solid State 9 27th June 2008 08:44 PM
Help designing Input and Vas stage's DoomPixie Solid State 28 13th January 2006 09:28 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
