Class A Sounds Mighty Sweet!
Old 5th March 2011, 01:52 PM   #11
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default C12 is really big...is this really needed?...say...so big one?
This uses to slow down the amplifier....and you see your square wave shows something less than perfect... well, very good job you have done..thank you as you are sharing with us.
regards,
Carlos
I am alive and healthy folks... for Brazil only product: https://www.youtube.com/watch?v=6A_g8uPHHO4: https://www.youtube.com/watch?v=DTXl1eEgygk
Old 5th March 2011, 01:55 PM   #12
jgray is offline jgray  United States
Bigun, I think your hunch is right regarding the cap on the phase splitter. I tried a capacitor in the 300pF range and I still had some ringing which I didn't like, but I bet there is an intermediate value that would be better. I may order a selection and do some further experimentation.
Joel
Old 5th March 2011, 02:01 PM   #13
Jam, I calculated a value for R6 that was less (about half), but in simulation it showed minimum distortion at a higher level. I tried it with both and couldn't hear or see a difference so I went with the value from the simulation. Thanks, Joel
Old 5th March 2011, 05:16 PM   #14
Bigun is offline Bigun  Canada
Bigun's Avatar
Joel
This issue with ringing can be a 'red herring'. I've looked at this recently and found some popular opinion that it's just a case of compensating the amp until it's smooth, as you've done, but I've seen some more considered thoughts on the internet pointing out the flaws in this approach which suggests that some ringing is 'OK' and preferable to over-damping.
For the kind of topology you have, with the LTP input, a compensation capacitor around 100pF should be much closer to the right value. In my own experiments I found the value had a subtle but repeatable impact on the sound. A value too high makes the sound a little dull, a value too low makes the high end too bright and somewhere in the middle you find the magic in the sound.
JLH was very wary of this kind of compensation too.
Keeping speaker cables reasonably short, and not using esoteric high capacitance speaker cables or speakers helps.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 5th March 2011, 06:13 PM   #15
That is very interesting. Now I want to try taking it down to a lower value and see what happens; both on the scope, and with my ears. Guess I am going to have to order some more parts
Old 5th March 2011, 06:44 PM   #16
Bigun's Avatar
It's all part of the fun for sure. A handful of values, and using some in parallel allows for quite a bit of experimentation. Modify one channel only and compare the two channels.
Be careful driving your amp with a square wave - I blew one up like that - square waves really stress the output devices. At full power it will blow it up before you have time to adjust your scope - at least it did for me !
Old 6th March 2011, 02:21 AM   #17
WuYit is offline WuYit  Sweden
Banned
We deeply regretted that square wave event caused by an allegedly advanced, but in point of fact deficient compensation method.
Old 6th March 2011, 02:42 AM   #18
Bigun's Avatar
Indeed, may those poor silicon 3-legged friends rest in peace
Old 6th March 2011, 03:06 PM   #19
magnoman is offline magnoman  United States
my musician sons both said it sounded “Not Too Bad, ”
Joel, very impressive (first amp or not) I doubt any additional congrats compare with NTB. I really like the clean build, and clean square wave response (20V/us seems sufficiently fast to me for 10V rails). Your thought out responses reveal the care that went into this.
Interested in hearing what your final tweaked preferred listening values are.
-Antonio
Old 6th March 2011, 07:05 PM   #20
schiller is offline schiller  Greece
regards,
Carlos
It is a 20 kHz square wave, and it is an audio amp, not a MW transmitter. For the second you need a better square wave indeed.
Class A Sounds Mighty Sweet!Hide this!Advertise here!
"Mighty Mite" Single Ended Amplifier wrenchone Tubes / Valves 13 20th October 2008 04:57 AM
clean, wrm, sweet sound amp CLass A space2000 Solid State 64 11th May 2008 05:01 PM
JLH vs Mcintosh class B amp which sounds good wleediy Solid State 0 10th July 2007 08:17 PM
Question for all mighty ILIMZN and others... bogdan_borko Solid State 36 10th February 2006 11:45 AM
