Good Sub for 2SA961S grade B or C
Old 4th March 2011, 09:07 PM   #1
eyoung is offline eyoung  United States
eyoung's Avatar
Default Good Sub for 2SA961S grade B or C
Hey y'all I'm looking for a good substitute for a Toshiba 2SA961S TO220 to replace in my Yamaha B2 meter board. It is used as a voltage regulator...Any recommendations?
Regards, Elwood
"Lead me not into temptation...I can find it myself."
Old 5th March 2011, 02:59 AM   #2
jaycee is offline jaycee  United Kingdom
if its just used as part of a zener regulator, any TO-220 device should work, such as a TIP41C. I cant find anything about the 2SA961 though.
Old 5th March 2011, 08:59 AM   #3
Bigred is offline Bigred  Canada
Whats the PCB board designator (TR3xx)? Are you sure your not referring to 2SA671? A TIP41A will get the job done for that.
Good Sub for 2SA961S grade B or CHide this!Advertise here!
Rebuilding a DAC Audio grade or Computer grade caps? gto127 Digital Source 0 28th January 2009 08:17 PM
Need PCM63-K grade beauty_divine Swap Meet 0 26th March 2008 12:41 PM
Computer Grade/Inverter Grade Cap TunaFish Parts 2 11th March 2005 02:51 PM
Computer Grade Cap or Inverter Grade Cap??? TunaFish Tubes / Valves 10 11th March 2005 07:48 AM
pcm1702, K grade or not? PatPet Digital Source 30 2nd December 2004 01:51 PM
