Old 4th March 2011, 06:23 PM   #1
Default Sony TA-F606ES channels unbalanced.
Hi.
This amp got a lower left channel or somewhat a bit "muffled" in the top region. Tried cleaning the volumepot, a 4 pin type with center tap. I took the pot apart and had a look at it, no obvious tracks or other fault. Adjusted the bias to specified 24mV on both channels, no change. Sanded the output relays, same result. Could it be a dry cap or something in the center tap circuit messing up? Itīs a nice amplifier, mosfet driver and output stage. I would really like to get it sorted so I can use it for preamp paired with a couple of TA-N55ES. I have the servicemanual if anybody care to take a look at it. Itīs not easy to find a new pot either since itīs a 120k type and have the center tap..
Old 4th March 2011, 06:25 PM   #2
GoranB is offline GoranB  Poland
GoranB's Avatar
Send the service manual ill try to help
Old 4th March 2011, 06:53 PM   #3
GoranB's Avatar
A four pin type pot is used when in the preamp is loudness switch. It doesnt have to be a big problem to buy it. Try to take a look at circuit board from the bottom side, look carefully if all solder point are good soldered. Replace the input capacitors with same value ones, voltage and capacitance. I would change all capacitors. I dont know if you have the same problem on all inputs. Maybe some there are capacitors and resistors, check the soldering points.
Old 4th March 2011, 07:00 PM   #4
GoranB's Avatar
if your Sony have separated preamp board try to connect the outputs to another amplifier or to headphones. If all is fine, then you have a problem with power amp. If oposite, your preamp is the reason of the bad sound. Also you can skip the vol. pot. buy adding a 2 ressistors one in serie with inut signal and the second one to the ground. To ground try 47K and you can use 470k for input in series.
Old 4th March 2011, 07:01 PM   #5
The amp does not have a loudness button. I have a regular alps 100k 3 pin type, what happens to the circuit if I put it in for a test?
Old 4th March 2011, 07:04 PM   #6
GoranB's Avatar
Maybe your speakers are damaged, change the left speaker to right chanell and listen if you still have the problem.
Old 4th March 2011, 07:09 PM   #7
GoranB's Avatar
Its hard to say without service manual what will happen if you put the 3 pin pot. As i said, try to locate the point when preamp and power amp are connected. take inputs from pream and use headphones.
Old 4th March 2011, 07:18 PM   #8
Have tried several pairs of speakers, sources etc. Tried headphones just now, same imbalance and does not change pressing the mono switch or source direct. Iīll happily send you the manual, just need your email adress.
Old 4th March 2011, 07:21 PM   #9
GoranB's Avatar
rozmarihunter@yahoo.com
Old 4th March 2011, 07:26 PM   #10
11mb manual sendt.
Are all four channels of Sony XM-504z same goldyrathore Solid State 6 15th July 2010 02:26 PM
Sony TA-FB730R littlerick Chip Amps 1 9th December 2009 09:55 AM
Sony TA-P717 doomsweek Parts 0 18th December 2007 11:48 AM
Sony TA-N1 and TA-NR1, how do they sound? lumanauw Solid State 0 28th November 2006 01:51 AM
FS: Sony "Esprit" TA-E901 and TA-N901 pre and power amp MJR Swap Meet 1 6th December 2003 07:55 PM
Page generated in 0.10593 seconds (73.90% PHP - 26.10% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
