i have only available a, 17.7-0-17.7 ac power transformer,
![]() ![]() the PT will power this rectifier, ![]() max input 33vacthe rectifier power supply will supply this set of TDA7294 amps with 25vcd. ![]() the 35 VTC (17.7-0-17.7) transformer is the only PT i have within range of the amp chip, witch is Input voltage i have 25v but should i be concerned for response? ok my question is how will 25v compare to say the recommended 36v??????? i know the lower volts will lower wattage, but iam not concerned with watts, i only have high efficiency tube amp speakers. any input will be greatly appreciated! oh ya, can any speculate or identify the amp rating on the transformer pictured on top?, mounted to guitar amp, the 7294 should be gettin 1A-1.5A, will the PT be ok? |
#2 |
ok say if the VA rating on my power transformer is underrated, what will be result, will it be ok?
| How to design input stage with specific input impedance/pot value | mahleriana | Tubes / Valves | 0 | 16th November 2009 09:37 PM |
| 15V from 25VAC/36VDC | jimbo1968 | Power Supplies | 6 | 18th July 2006 07:21 AM |
| Best way to power a 12vdc fan from 25vdc for an Aleph30 | hifimaker | Pass Labs | 16 | 16th December 2005 08:36 PM |
| Sprague 36D 35000uF 25VDC -10%/+100% | kjunom | Swap Meet | 0 | 27th December 2004 08:30 PM |
| TDA 7294 PCB - need help :) please | Szaflik | Chip Amps | 3 | 17th December 2004 08:51 AM |
| Page generated in 0.08136 seconds (58.44% PHP - 41.56% MySQL) with 10 queries |
