Old 2nd March 2011, 03:50 PM   #1
Default 85vDC - 12vDC
hi there
I have a power supply of + & - 85vDC, (65-0-65vAC)I would like to know if there is a way instead of using another transformer, that i can somehow use a simple circuit to get 12vDC from that supply to run a fan.
Old 2nd March 2011, 04:23 PM   #2
jaycee is offline jaycee  United Kingdom
The usual way is with a zener based regulator, but the transistor is going to get far too hot with that kind of voltage drop. you'd probably be best using a mains-powered fan in this case.
Old 2nd March 2011, 05:34 PM   #3
HighTec is offline HighTec  Croatia
HighTec's Avatar
Here is a fan control circuit used in Yorkville's amplifiers, AP3400 and AP6040. The Darlington MJH11018 is obsolete but you can use MJH11022 which is still manufactured by ON Semiconductor. Some minor component recalculations needs to be done in order to work with you power supply. Of course, MJH11022 needs to be mounted on a heatsink. If you wanna complete schematic, give me the details via PM.
Edit: Here is the link for AP3400 service manual.
http://www.yorkville.com/downloads/other/smap3400.pdf
Old 2nd March 2011, 05:42 PM   #4
Mooly is online now Mooly  United Kingdom
Mooly's Avatar
You could investigate using a "wattless" dropper where a capacitor is used in place of a resistor.
Rectify the supply and scale the cap/s to give around 12 volt or aim a little higher and use a simple reg.
You would have to elaborate on it but this is the idea,
UK Vintage Radio Repair and Restoration - Dropper Calculations
A simulation free zone. Design it, build it, test it.
Old 3rd March 2011, 01:34 AM   #5
djk is offline djk
djk's Avatar
If its a toroid, wrap a few turns on it for the fan.
Candidates for the Darwin Award should not read this author.
Old 3rd March 2011, 01:41 AM   #6
indianajo's Avatar
Use a wall transformer , most fans produce electrical noise anyway. Keep fans off the audio circuit. I've got my fan outside the steel box of my ST120.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500
12VDC Class-D Chips speaker Class D 3 9th February 2008 12:42 PM
12vDC to 12vAC Cxrazy Parts 10 21st January 2008 01:11 PM
12vac to 12vdc what all do i need Big_Tires Solid State 5 1st September 2004 11:33 PM
from 56vdc +/- to 12vdc +/- kinser Solid State 16 17th August 2004 08:36 PM
Page generated in 0.22694 seconds (26.09% PHP - 73.91% MySQL) with 10 queries
