i am interested to build a high performance pre-amplifier that can match with any solid state power amp. likely to be naim power amp or lavardin power amp.
a simple pre-amp with 3 to 4 input(Elma selector switch?) a good volume control (Noble volume control?) shielded power supply? solid-state rectification, regulation and capacitive filtering with resistor(vishay?) capacitor(murdoff?) cable(neotech UPOFC cable silver or copper?) chassis (anodised metal, heavy duty with soundcare footer) gain derived from tube (what tube 6n1p?) IEC socket but with which circuit? any simple circuit that a layman like me can build with no humming, no noise, and wont start a fire? Thanks in advance. |
#2 |
Hi
You may get better response and better threads to read about pre-amps in the "Analog Line Level" Forum. If you want tube pre-amp details, then the tube amplifier forum has lots to read too.
regards |
#3 |
Thanks. will repost in analog line level section.
| how to build a pre using S&B TX-102 transformers | krishu | Parts | 278 | 5th November 2012 07:28 PM |
| First Time Pre Amp Build | nikolas812 | Tubes / Valves | 3 | 2nd April 2009 01:20 PM |
| Best Pre-amp to build for a new DIYer? | hifimaker | Pass Labs | 30 | 3rd December 2003 01:53 AM |
| What's a good, basic pre-amp to build | Rino odorico | Everything Else | 0 | 18th February 2003 02:05 PM |
| Which pre-amp to build? | HooRide | Pass Labs | 16 | 11th September 2002 06:02 PM |
