Old 28th February 2011, 03:56 AM   #1
AllenB is online now AllenB  Australia
Default Capacitance multiplier, suggest improvements
I have this supply ready to power a dual rail class A amp. Can this circuit give low ripple, and hold a steady ground for low DC offset?
(EDIT: The lower rail in the picture should read -V, of course )
Old 28th February 2011, 04:08 AM   #2
MJL21193's Avatar
It won't work as drawn. Look HERE for some idea. - post #14 details a cap multi regulated supply that you can look at the structure of.
Old 28th February 2011, 04:08 AM   #3
RJM1 is offline RJM1  United States
More like this.
And the bottom supply should be labeled V-.
Old 28th February 2011, 04:09 AM   #4
MJL21193's Avatar
Yeah, that doesn't fix it.
Old 28th February 2011, 04:11 AM   #5
Yeah it does.
Old 28th February 2011, 04:20 AM   #6
MJL21193's Avatar
Originally Posted by RJM1 View Post
Yeah it does.
No, it doesn't.
Old 28th February 2011, 04:27 AM   #7
Yeah it does.
Old 28th February 2011, 04:30 AM   #8
Yes, thanks, I can get it to sim now. Is it OK as a practical circuit?
MJL, that's a monster you have there.
Old 28th February 2011, 09:20 AM   #9
Elvee is offline Elvee  Belgium
You should add resistors in parallel with the capacitors, to give the transistors more room.
Substituting a CFP for the darlington has a number of advantages: it improves the ripple rejection marginally, gives a DC output 0.7V higher, but more importantly, it reduces the output impedance by a factor 2.5.
Old 28th February 2011, 10:15 AM   #10
the added resistor parallel to the base cap is what makes it a capacitor multiplier.
Without the added resistor, the circuit tries to be a bad voltage regulator.
That added resistor !
Try a series pair of Zener and resistor. You can get cap multiplier action where output voltage tracks (a fixed % of ) input voltage at voltages lower than the "knee".
At input voltages higher than the "knee" the slope of output voltage vs input voltage brings in a little voltage regulation and this prevents excessively high voltages being sent to the client circuit when mains voltage is near maximum tolerance.
regards Andrew T.
Improving the capacitance multiplier Mr Evil Power Supplies 7 17th September 2011 11:00 AM
Capacitance Multiplier Kinnja Solid State 2 13th January 2008 08:12 PM
Capacitance Multiplier, Caps? roger-k Power Supplies 2 6th December 2006 11:43 PM
Finished capacitance multiplier Mr Evil Power Supplies 14 10th April 2005 10:36 AM
Page generated in 0.14589 seconds (58.08% PHP - 41.92% MySQL) with 11 queries
