Old 28th February 2011, 12:33 AM   #1
Default Parallel jfet question
In paralleling a couple of jfets how close do they need to match. Taking
the jfet BOZ for example if I wanted to run a pair of 170's in parallel instead of one jfet would I just match for idsa withen a ma or so. I have
something compleatly different I am just refering to this circuite as an example.
Old 28th February 2011, 01:00 AM   #2
jackinnj's Avatar
I match to 0.1mA Idss -- and then compare the gm of the matched sets.
fwiw, Pbf 2SK170's are pretty available now...
Old 28th February 2011, 08:06 AM   #3
In such a configuration matching is not critical as it only determines current sharing amongst the transistors; the paralleled transistor will effectively form a single transistor with higher Idss, matched or not. Just use an individual 10r source resistor for each transistor and you're fine.
Matching is important for differential pairs as this will affect DC offset, drift and CMRR/PSRR. But that's not what we have here.
Samuel
jfet distortion question woody Solid State 4 4th February 2010 11:57 AM
JFET question - Idss values JammyBStard Solid State 14 6th January 2010 01:54 PM
parallel lm3886 question ryan750 Chip Amps 2 23rd October 2008 09:37 AM
Dumb parallel question Cloth Ears Multi-Way 6 13th January 2006 05:59 AM
Dumb JFET Question EchoWars Solid State 2 3rd March 2004 09:08 AM
Page generated in 0.11663 seconds (51.66% PHP - 48.34% MySQL) with 11 queries
