Wiring a XLR plug
1 Attachment(s)
Hello everyone
I bought this Neutrik PCB mount 3 pole XLR plug from Premier Electronics. The XLR plug has 4 pins. As far as I know #1 pin should be connected to GND, #2 to Cold & #3 to Hot but I have no idea about #4 therefore would anyone please tell me what is the function or connection of the # 4 pin of this plug? Thanks. |
BTW in the US pin 2 is considered 'hot' and pin 3 'cold' but it's only a problem if the phase is reversed accidentally. G² |
Pin 4 would use a second shield or a drain wire to connect the two chassis together.
Pin 1 should be tested to exclude the Pin1 problem |
Thank you very much for your inputs. Yes I need the US connection therefore I will correct the pins to read as: Pin 1: Gnd Pin 2: Hot Pin 3: Cold |
Thank you very much for your inputs too. But I do not surely understand what do you mean two chassis and what is pin 1 problem. Please give more details. Thanks in advance. |
the XLR cable connects the two chassis.
Google gives 9.5M results to pin1 problem |
Pin #1 is NOT connected to Audio Ground.
Pin #1 is NOT connected to Power Supply Ground. Pin #1 is connected to the Chassis with a very short wire. |
Hi Andrwe & Kevin
I understand now. Thank you for giving the information. |
The pin 1 problem Andrew mentioned has caused many a problem with RFI or ground loops. My favorite explanation to pin 1 problems is found in Rane's Handbook.
Grounding and Shielding Audio Devices |
This is a very good and clear diagram for wiring. Thank you for attach it here. In this diagram, it has singal and chassis grounds, in addition, there will be a power ground, therefore there will have 3 grounds in an amplifier. Would anyone please correct me if I am wrong? |
| All times are GMT. The time now is 02:57 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
