Wiring a XLR plug - Page 3 - diyAudio
Old 1st March 2011, 01:49 PM   #21
SSDIY is offline SSDIY  Hong Kong
Originally Posted by JensH View Post
You have to swap the "+" and "-" inputs of the op-amps. Right now you have a positive feedback.
Hi JensH
Thanks for your inputs but I still not sure how to swap the + and - inputs of the two op-amps therefore submitting a drawing will be highly appreciated.
Old 1st March 2011, 11:28 PM   #22
Originally Posted by qusp View Post
nvm
thought about using transformers?
Hi qusp
Transformers are out of consideration for the time being. Thanks for suggestion.
Old 2nd March 2011, 07:25 AM   #23
Originally Posted by SSDIY View Post
Hi JensH
Swap pins 2 and 3. Swap pins 5 and 6. That's all.
G
Old 2nd March 2011, 01:47 PM   #24
G
Hi stratus
I have revised the schematic. Would you please check it for me?
Old 3rd March 2011, 08:38 AM   #25
Hi stratus
Looks like you nailed it. I think the junction of R2 and R4 should be tied to ground.
G
Old 4th March 2011, 02:03 PM   #26
G
Hi stratus
You mean something like this:
Old 4th March 2011, 03:35 PM   #27
No.
The two resistor junction should be connected direct to Signal Ground (Signal Return) in the top left.
The Signal current has to pass into the amplifier and has to pass back out. The current must go around a circuit, back to the origin.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 4th March 2011, 04:23 PM   #28
Speedskater's Avatar
I also suspect that the "SGND" in the lower right hand corner will be mis-wired to the output connector.
Kevin
Old 4th March 2011, 11:08 PM   #29
Hi Andrew & Kevin
Thanks for the comments.
What do you think about this revision:
Old 6th March 2011, 12:37 AM   #30
As long as you DO NOT connect the "SGND" to the output XLR's pin #1, that part is OK.
Kevin
FS: Switchcraft A3FB XLR & Kimber Kable RCA Plug Connectors bng Swap Meet 1 24th January 2014 04:10 AM
Help wiring power to 3 channel amp with one plug chevy2410 Chip Amps 57 30th May 2007 06:28 PM
Wiring for XLR input on unbalanced amp Arx Chip Amps 3 16th April 2007 06:57 AM
silly XLR wiring question... dorkus Everything Else 23 16th March 2004 01:03 PM
XLR Audio Input Wiring haldor Parts 0 5th February 2003 02:59 PM
Copyright 1999-2017 diyAudio
