Wiring a XLR plug - Page 2 - diyAudio
Old 28th February 2011, 01:41 AM   #11
SSDIY is offline SSDIY  Hong Kong
Enclosed is a schematic of the Unbalance to Balance Converter which I am going to build. It seems to me that the drawing of Input Signal and Input Ground is an error drawing. Would anyone clarify for it?
Old 28th February 2011, 01:58 AM   #12
imix500 is offline imix500  United States
imix500's Avatar
Yes, there appears to be a junction dot that should not be there between Input Signal and Signal Ground.
Old 28th February 2011, 04:57 AM   #13
Personally I'd use lower value build out resistors - maybe 27 rather than 120 ohms and also delete the capacitors - but that's just me.
G
Old 28th February 2011, 01:53 PM   #14
Hi imix500
I re-draw the schematic but I am not sure if it is correct or not. Please comment. Thanks
Old 28th February 2011, 02:02 PM   #15
G
Hi stratus
What would be the different if change resistor value from 120 Ohm to 27 Ohm in this circuit? Please advice.
I do not feel comfortable with the 47uF capacitors too but as far as I know they are coupling capacitors for blocking the DC at output stage, deleting these capacitors probably will create a DC voltage to harm the power amplifier and speakers. What do you think?
Old 28th February 2011, 02:07 PM   #16
JensH is online now JensH  Denmark
You have to swap the "+" and "-" inputs of the op-amps. Right now you have a positive feedback.
Old 28th February 2011, 03:25 PM   #17
Another Unbalance to Balance converter from Rod Elliot.
Old 28th February 2011, 03:36 PM   #18
qusp is offline qusp  Australia
qusp's Avatar
nvm
thought about using transformers?
Old 28th February 2011, 11:56 PM   #19
Speedskater's Avatar
I still see the XLR output pin #1 connected to audio (circuit) ground.
Pin #1 is not part of the audio circuit, it only connects to the chassis/enclosure. And then with a 2cm (or less) wire.
Kevin
Old 1st March 2011, 12:55 AM   #20
For my own use I use a low value resistor in the ground line. Most ground loop _Voltages_ are quite low but the currents can get high. A 10 ohm resistor in the ground line will drop those currents dramatically. Don't worry about hum. That's why you have balanced audio.
G
FS: Switchcraft A3FB XLR & Kimber Kable RCA Plug Connectors bng Swap Meet 1 24th January 2014 04:10 AM
Help wiring power to 3 channel amp with one plug chevy2410 Chip Amps 57 30th May 2007 06:28 PM
Wiring for XLR input on unbalanced amp Arx Chip Amps 3 16th April 2007 06:57 AM
silly XLR wiring question... dorkus Everything Else 23 16th March 2004 01:03 PM
XLR Audio Input Wiring haldor Parts 0 5th February 2003 02:59 PM
Copyright 1999-2017 diyAudio
