Old 26th February 2011, 02:24 PM   #1
LAJ is offline LAJ  United States
Default Kenwood KRV5570
Need help on a KRV5570 tuner amplifier (without the "D" suffix). Need the values of R127 & R129 on the power supply/ amplifier board. Note this amp has transistors rather than chip amps.
A schematic would be appreciated. Thanks all!
Old 24th March 2013, 03:56 AM   #2
I know this post is old. Just for record, I took the measurement and both are 3.9K. However, when I check the circuit, it stated as 39K, can some confirm?
Also what is the value of the R80, 10 ohm? Why these resisters only 1/4w which over heat until can not read the color code.
Old 25th March 2013, 02:32 PM   #3
Default Thanks for responding...
That's a good question.
3.9K seems right.
Why do they overheat till you can't read them?
I think my R80 is OK but I'll check the value and get back with you.
Thanks again.
Old 25th March 2013, 04:23 PM   #4
3.9K seems right.
Thanks again.
LAJ, Thanks. I believe R127 and R129 act like a load resister. Anyway, I replaced with 39K and now less heat, just warm. My unit suffer power on and cut off before speaker relay activate. The problem is CN02 on the amp board bad contact. I cut off the wire and re insert again and the unit back in operation.
Old 25th March 2013, 06:05 PM   #5
Default Thanks!
I'll give that a try!
Kenwood 9102 mike49504 Car Audio 38 16th November 2009 04:02 AM
Kenwood thunder Chip Amps 3 20th February 2007 11:58 AM
kenwood 923 mike49504 Car Audio 5 20th October 2006 12:13 PM
kenwood 9102d mike49504 Car Audio 13 18th October 2006 01:14 PM
PLEASE! Kenwood help! mjarve Solid State 1 23rd September 2004 04:04 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
