#61 |
That sounds promising...
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#62 |
It certainly was, the amp sounds amazing, such a vibrant sound with masses of bass control. Can't wait till I've let it settle in a bit, open up the pipes a bit.
Hopefully I wont be found on this forum again! |
#63 |
I'm sure you will
![]() Well done anyway... another diyAudio success story.
#64 |
Good to hear that you've got it working!
What did you end up using for output devices? |
#65 |
Hi Pete, I used an ONSemiconductor 2N3773G. It seems to be working very well, will just have to see how it holds up over the next decade, hah. And I think you're right Mooly, probably am going to stick around!
Thanks again for all your help guys! would have been a goner without it!
#66 |
im sure you'll be back - next interest might be building an amp of your own
#67 |
Funny you should say that...
#68 |
see, you just cant help it after you've been here !
| Armstrong 626 problem | Paul318UK | Solid State | 1 | 26th February 2011 11:26 AM |
| Overhaul | moermusic | Solid State | 0 | 13th February 2010 07:05 PM |
| armstrong amplifiers | sakis | Solid State | 5 | 4th January 2010 04:45 PM |
| Armstrong 521 Amplifier | seanww69 | Solid State | 9 | 11th July 2007 10:13 PM |
