Need help understanding current sourced common emitter/source amplifiers
Old 25th February 2011, 01:41 AM   #1
GregH2 is offline GregH2  Australia
GregH2's Avatar
Default Need help understanding current sourced common emitter/source amplifiers
Hello all,
I'm still having trouble grasping a basic amplifier concept I'm hoping you can help with. I'm thinking out loud here so bear with the lecture.
With a common emitter/source amplifier, as most of you will know, it is common to add an emitter resistor (Re) and collector Resistor (Rc) to stabilise the gain and make gain more or less independent of transistor variations. So gain essentially becomes Rc/Re (within reasonable limits).
So we now have a circuit that can be used in multiple amplifiers and perform in much the same way despite transistor variations.
One way to improve linearity and reduce distortion is to replace Rc with a constant current source, which if well designed has essentially infinite output impedance.
This means that gain theoretically becomes infinity/Re, but obviously gets limited by the transistor transconductance and other transistor properties.
So my question is, how do you make a simple current sourced common emitter amplifier operate independently of transistor variations?
I need to make two channels of an amplifier, and each has a current sourced common source jfet input. How do I make both input stages have the same gain without either removing the current source or resorting to a LTP input?
Any advice you can provide will be appreciated!
Greg.
Old 25th February 2011, 04:58 AM   #2
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
The voltage gain is:
Av= GmRl
Where Rl= 1/Hoe || Rc || Ri (next stage/load resistance)
1/Hoe being the inherent collector dynamic resistance. You can usually ignore it with minimal errors since Rc is usually ~an order of magnitude smaller. An active load can increase gain by making:
Av=~ (1/Hoe)Gm (no load)
I wouldn't worry about it. You could always match transistors, but for the most part, the gains won't be that far off for any reasonable design. How much gain do you really need here anyway? How accurate do you need to be?
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 25th February 2011, 08:46 AM   #3
Samuel Groner is offline Samuel Groner  Switzerland
Active load techniques are not particularly useful without feedback for the reasons you mention. They are mostly seen within opamp topologies where global feedback stabilizes the operating point.
Samuel
Old 25th February 2011, 10:52 AM   #4
the active collector load will almost certainly not have constant impedance across the whole passband of the amplifier. This results in gain that varies with frequency and confirms SG's need to apply NFB.
JLH shows a variety of one, two and three transistor amplifiers with different ways of providing AC feedback and DC feedback. All these circuits appear individually in other papers, so far I have only seen the collection of them in "The Art of Linear Electronics"
Where else can we find a comprehensive collection of feedback scenarios for the one to three transistor amplifiers?
regards Andrew T.
Old 25th February 2011, 12:11 PM   #5
GregH2's Avatar
OK thanks, I will get JLH's book and look into local NFB options. In the mean time I'm going to play with some simulations and build some test circuits.
Greg.
Old 25th February 2011, 12:17 PM   #6
JLH's The Art of Linear Electronics is out of print.
It was published by Newnes isbn 0-7506-3746-3
I consider this my best electronics reference book.
Better than Horowitz and Hill and the ARRL handbook.
It is a good complement to Self and/or Cordell.
Those 5books + a number of briefer pamphlets & small paperbacks cover most topic I need to consult.
regards Andrew T.
Old 25th February 2011, 08:59 PM   #7
Ian Finch is offline Ian Finch  Australia
Chapter 3 of Self's recent title "Small Signal Audio Design" is all about discrete amplifier circuits in the standard categories of single, 2 and 3 transistor amplifiers and opamps. It's yet another book but this one is right in the audio ballpark with up to date analyses.
As a comment, the book is light on theory whilst retaining essentials and thorough on evaluation and choices as would be necessary for any DIYer to make. BJT in this chapter only.
The publishing details and a little more on discretes are on The Douglas Self Site
Ian
Old 26th February 2011, 02:59 AM   #8
GregH2's Avatar
OK thanks all, I will track down those books. Ordered the JLH one already.
Greg.
Old 26th February 2011, 03:02 AM   #9
GregH2's Avatar
Thanks Miles,
Well I don't know really. I just assumed they would need to be pretty close if they're for the L and R channel of the same amp. So you think I'm worrying too much then and that I should just build it as is and match Vgs as best I can?
Old 26th February 2011, 06:14 AM   #10
Yes.
www.dolphin-hsl.com
Need help understanding current sourced common emitter/source amplifiersHide this!Advertise here!
Common Source versus Common Drain output stages alaskanaudio Solid State 36 1st June 2014 02:35 AM
Basic Common Emitter Amp Help Obe1 Analog Line Level 99 21st February 2010 05:08 PM
Current Sourced Cathode Follower dr._sleep Tubes / Valves 8 27th February 2006 08:46 PM
Current sourced heaters in a CF Salas Tubes / Valves 21 31st May 2005 09:35 PM
Current sourced heaters Salas Tubes / Valves 3 26th January 2004 11:09 PM
Copyright ©1999-2017 diyAudio
