hey , need a professional software to simulate an AB amplifier
i have a problem with crossover distortion and i dont have an oscilloscope why do they add current mirror in the front end of the class a amplifier? why when i add a pot and transistor to the bias section the driver transistor will heat? Last edited by yosha; 24th February 2011 at 04:37 PM. |
#2 |
For the simulation software I would suggest you check out the fourm called "software tools". Your other questions are kind of scattered. Meaning too little information on two wide of topics, but I will try. What makes you believe that your have crossover distortion if you dont have a scope? What is the brand and model of the amp? You must give information if you want others to help.
Bob |
#3 |
im workin on a class ab amp , i found the schematic on 300/500W Subwoofer Power Amplifier
my supply : +-56v 5A load : 8 ohms output stage:2sa1943 - 2sc5200 so the shcematic does not include a bias regulation..so i added it by a potentiometer and a transistor to the both of the base of the driver transistors..so when i switch the pot the drivers will heats and when i reduce the amount they will cool..so when they heat they are sonducting more current and then the crossover distortion will be reduced right?that's what i read thank u |
#4 |
that supply can feed a 10r resistor with current.
The maximum AC output power using a sinewave will be ~50^2 / 10 / 2 ~ 125W into 10r. A speaker can draw upto three times as much current as the equivalent resistor. 5Apk will restrict you to using a 20ohm to 30ohm speaker. The maximum power into a 30ohm speaker is ~42W into 30ohm. If you want to use an 8ohm speaker then you must find a way to supply at least 15Apk (preferably >=20Apk) through the amplifier to the speaker. This will allow a maximum power of ~ 150W into 8r0 and be capable of driving an 8ohm speaker. Last edited by AndrewT; 25th February 2011 at 11:04 AM. |
#5 |
"Because this amp operates in "pure" Class-B (something of a contradiction of terms, I think), the high frequency distortion will be relatively high, and is probably unsuited to high power hi-fi. At the low frequency end of the spectrum, there is lots of negative feedback, and distortion is actually rather good, at about 0.04% up to 1kHz. My initial tests and reports from others indicate that there are no audible artefacts at high frequencies, but the recommendation remains."
I got this from the page you gave us... So why did you add a potentiometer? And the current mirror will make the amplifier more linear, improves "PowerSupplyRejectionRatio" and it wil make the slew rate better. Someone correct me if I'm wrong.
FET fanatic
#6 |
brian : the pot i added it to control the bias current..and at low signal level i can hear a few distortion so i change the value of the pot and the distortion will disapear but the driver transistors will get more heat like they are conducting all time...so how can i convert this amp to class AB...and how can i calculate the current mirror and how do i know how many transistors will i add..or simply do u have a gd schematic to work on? thnx
#7 |
This amp is designed as a subwoofer amplifier. When you change the value, you will change the quiescent current. That's the current that will flow throug your transistors, all the time. If you want to make a powerfull hifi amp, this is not the right choice.
Anyway, I think you've already made it a Class-AB by adding the pot. It's absolutely normal that your transistors heat up.
FET fanatic
| Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? | tiefbassuebertr | Solid State | 19 | 3rd May 2013 05:31 PM |
| Class AB Audio Amplifiers | Cristi | Connexelectronic | 83 | 15th March 2013 06:29 PM |
| Class AB, Class AB Non-Switching, Class AB Soft Non-Switching | steph_tsf | Solid State | 4 | 15th March 2010 03:39 PM |
| Can a Class AB PP amp be said to be operating in Class A at low signal levels? | ray_moth | Tubes / Valves | 19 | 23rd January 2009 07:52 PM |
| Thermal design for Class AB amplifiers | mbroker | Solid State | 3 | 24th September 2002 03:03 AM |
