diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   rotel RA-311 left channel noise (http://www.diyaudio.com/forums/solid-state/183769-rotel-ra-311-left-channel-noise.html)
mogga 23rd February 2011 11:36 AM
I recently acquired a rotel ra311 amp but only the right channel works properly. the left channel has a loud hum even when the volume is on its lowest setting. I recently replaced the fuses so it may have something to do with that.
jaycee 24th February 2011 10:44 AM
If the fuses blew it means the channel has a fault. How much experience do you have in electronics repair?
east electronics 24th February 2011 11:48 AM
schemtaic is available in case you can read it ...
mogga 26th February 2011 08:17 AM
Originally Posted by jaycee (http://www.diyaudio.com/forums/solid-state/183769-rotel-ra-311-left-channel-noise-post2481122.html#post2481122)
not very much I'm afraid, however I know the basics of electronics and can solder
Resources saved on this page: MySQL 18.75%
