Having lasts 10 pairs of original's TOSHIBA 2SA1943 and 2SC5200, I decided to put'em on work and made an amplifier for high freqvency drivers or speakers, more in parralel.
The amplifier is fully capable driving 2 ohms loading, all the time. Power around 140 watts on 8 ohms, 250 watts on 4 ohms and 420Watts on 2 ohms x2 channels. The amplifier have 2x56Vcc idle, @ 230 volts , 1,5 sec softstart delay, noise filter TDK 2x15A, against pop and noises from network power supply , protection against shortcircuit at output, it action at 1,5 ohm dummy load, and thermal protection at 100 celsius degrees, wich cuts down primary trafo power supply, letting only 12Vcc for FAN and command ciscuits from separately 12 volts 1A supply. Output devices are 5 pairs 2SC5200 & 2SA1943 each ch (5/rail), prefinals are NJW0281 & NJW0302 with BD441 superdiode. All components used are high quality for a high quality product ! OFFSET-UL are under 5 mv/each output. During tests, soket supply was around 221 volts, dropping low till 214 volts, primary transformer was made for 230 volts. Pictures during construction: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Movies during tests, choose 720p on youtube: Intro: http://www.youtube.com/watch?v=vhXnY78sBeA Testing on 8 ohm dummy load: http://www.youtube.com/watch?v=CQujXEi0AqY Testing on 4 and 2 ohm dummy load: http://www.youtube.com/watch?v=CR_Mt2dM1GA http://www.youtube.com/watch?v=d-L6v1t6wXE Testing 2x4 ohm dummy load: http://www.youtube.com/watch?v=8kpcbfJPxDM Offset measurement: http://www.youtube.com/watch?v=9k3R0wUUk08 Testing on speakers with audio signal on 1,5-1,6 ohm load: http://www.youtube.com/watch?v=HXBQ9dT4jkw http://www.youtube.com/watch?v=JUkLWhtlGHU http://www.youtube.com/watch?v=BJylldj61Fk Pay more attention from here: http://www.youtube.com/watch?v=ObgqAqm5DdE http://www.youtube.com/watch?v=yMVy19JaBUY http://www.youtube.com/watch?v=ojjVENKIuuM http://www.youtube.com/watch?v=pqPobUJQBGg Quality audio http://www.youtube.com/watch?v=mUiDzISZVaY Last edited by DjLeco; 21st February 2011 at 11:17 PM. |
| 1600 watt into 2 ohms MOSFET power amplifier | nigelwright7557 | Vendor's Bazaar | 2 | 2nd July 2010 11:06 PM |
| Can I make a 215GX stable at 2.5 ohms | mitchyz250f | Car Audio | 2 | 7th March 2008 02:09 AM |
| power amplifier 400w @ 4 ohms | divojara | Solid State | 8 | 22nd June 2007 06:54 AM |
| 2 Ohms stable Transistor Amplifier... | SkinnyBoy | Solid State | 14 | 1st April 2003 01:27 PM |
| Page generated in 0.12164 seconds (62.23% PHP - 37.77% MySQL) with 10 queries |
