Stolen Trademark Amplifier from Jim's Audio on EBAY - Page 43 - diyAudio
Old 7th May 2013, 10:58 PM   #421
Kaplaars's Avatar
Haha, yes it is nice, isn't it :-D Very elegant French made design. Unfortunatelly Audioanalyse went bankrupt many years ago, but there are still a few A9's around. It's bigger brother, the A90 has even been displayed in the NY museum of modern art. That one has twice the outputs and twice the amounth of cooling compaired to mine. I've totally restored this amp from scratch. The amp was a real mess when I got it, it had been maltreaded badly by its previous owner .
When I had got it, all the connectors were desintegrated, a power transformer was burned out because of a combination of a main capacitor that went fully short circuit + using the wrong fuses. So replaced both transformers by two nice Amplimo's that can deliver even more current at the same voltage, replaced all 20 mains capacitors, one channel was gone (outputs went short) so replaced them aswell (the A9 uses MJ15003/MJ15004 aswell) and almost every other electrolytic capacitor has been replaced also. So basicly I totally rebuild it, but with respect to its origin
Before (spot the differences ):
All connectors desintegrated, capacitors gone:
Without heatsinks:
New caps (bought them via Diyaudio ):
Resulting after restoration in:
It is like new again :-D. I love it's sound. Its sound stage is pretty much comparable to the Krell, although the Krell has more power. Also it's electrical design has some similarities with Krell. They are from the same era (my A9 is from 1989, just one year older than me )
(Sorry for going slightly offtopic )
Michael van den Born - PA4MW - Projects - YouTube
Old 8th May 2013, 02:25 AM   #422
spurlte is offline spurlte  United States
Really a nice job there Kaplaars. I am free to play with the monster tomorrow. Time to start chopping wires and attach terminals. Finally
Old 8th May 2013, 04:47 PM   #423
dudaindc's Avatar
Thanks for going off-topic.
This is a nicely done restoration project!
"All measurements are wrong! Thus, measurement is the art of handling errors."
Old 8th May 2013, 05:12 PM   #424
Kaplaars's Avatar
Thank you ! Hahaha, and offcourse thanks for the capacitors Dudaindc! They are perfect for this project, exactely the right size and capacitance, they fit like a glove.
Old 9th May 2013, 12:19 AM   #425
Default multiple capacitors
I always wondered about multiple capacitors versus Can Type capacitors.
Old 9th May 2013, 10:59 AM   #426
Kaplaars's Avatar
Hi David,
There are a few advantages when using multiple capacitors in parallel. In contrast to resistors, the overall capacity doubles when putting two capacitors in parallel. A capacitor has of course a capacity, but also an internal resistance (ESR= equivalent series resistance), and behaves a little bit like a resistor (so they are not ideal). When putting a few capacitors in parallel the capacity increases, but the over all resistance decreases (just like a resistor, for example when putting lets say two resistors of 5 ohm in parallel, the over all resistance becomes 2.5 ohm). This is very favorable, because less resistance means less dissipation. Dissipation is something a capacitor does not like, because dissipation means heat, thus the internal fluids (dielectricum) will boil out faster because of higher internal temperatures. Therefore the dielectrical layer becomes thinner, and is more likely to go down. The capacitor will 'pop', because the electric layer becomes to thin. Therefore measuring capacitance at capacitors is not always a good indicator of it's condition. When the dielectric layer becomes thinner, the capacity will get higher. So one could think a capacitor is okay, while it is actually dying. A few posts back I've posted some info about measuring leakage current when I've started up my capacitors. This is a great test. If the leakage current is too large (and thus the ESR), you can throw the capacitors in the bin . This process of degrading capacitors happens in a lot of 'modern' equipment like LCD tv's were manufactures save on capacitors. These inferior capacitors can't cope with high temperatures, and go down very fast. I've repaired a few TV's by just changing the capacitors
Especially in switching PSU's (like the ones used in LCD's, or in modern HYPEX amps) you need capacitors with low ESR. Normal ones will go down pretty fast because they heat up to fast.
But it is not all sunshine, running multiple capacitors in parallel has also a disadvantage. Chances of failure will rise, because there are more capacitors and thus there is more chance of failure. Also the first capacitor in row gets the lionshare of current during power on. Typically this first capacitor goes down before the others (just like in my Audioanalyse). So you have to be sure you use the right fuses. In the previous pictures you can see what short circuit can do to a transformer. Yes, like Gordon Ramsay would say 'THAT ONE IS OVERCOOKED'.
So when wiring the KSA pay very much attention to fuse all the wires that carry a lot of current. I fused the primary side of both transformers, and all four secondary leads of the transformers. I've also fused the little transformer that powers my speaker protection circuit.
Old 9th May 2013, 11:45 AM   #427
Default Fuses
Hi David,
Where there is the student, there is a teacher. Wonderful. Slow or fast fuses?
Old 11th May 2013, 03:53 PM   #428
Default Getting There
Hang in there guys. It is slowing coming together and hopefully getting there. Hey! How about 20mins of Rare Earth"s "Get Ready?"
Old 11th May 2013, 04:22 PM   #429
alibear is offline alibear  United Kingdom
alibear's Avatar
Hi all , OK I have decided to order boards from JIMS Audi. Does anyone know of equivalents to the 2SK2013 and 2SJ313 FET's .
Alan
Old 11th May 2013, 04:47 PM   #430
Kaplaars's Avatar
Hahaha Hmm what I would prefer are slow blow (SB) fuses at the primary side of the transformer (because of the large inrush current caused by the transformer) and fast blow (FB) at the secondairy side of the transformer.
By the way nice setup David! Finally the fun part can begin!
Alibear; the original FETS are still around. I've bought a couple via this forum. Via DIYaudio member Zhoufang. You could try to contact him if he has still a few around. See:
FS: Toshiba 2SK2013 / 2SJ313
Jim's Audio Goldmund Telos 390 clone Tyimo Solid State 12 8th March 2015 01:41 PM
Jim's Audio F5 power supply board Hikari1 Pass Labs 35 4th December 2013 11:41 PM
Jim's Audio F5 referenced kit. HiVi Guy Pass Labs 21 22nd November 2012 11:24 AM
Stolen items? kctess5 Multi-Way 14 23rd February 2012 11:02 PM
Copyright 1999-2017 diyAudio
