Stolen Trademark Amplifier from Jim's Audio on EBAY
Old 6th April 2013, 11:58 PM   #391
Kaplaars is offline Kaplaars  Netherlands
Kaplaars's Avatar
@Fix; Cool to see you here, I would love to see another build from your hand!!! :-) You were a big inspiratory to me for building a KSA myself. When I saw your build journals in the other KSA thread, I thought immediately ‘I WANT ONE TOO’ . By the way fix, how much difference made it for temperature when you cutted the bottom panel open for the tunnel coolers? I have the same cabinet as your, but I use slightely larger cooling tunnels. I am still thinking about making holes for the new tunnel coolers in the bottom plate too, or just using the holes that are already in the bottom plate to gain fresh air. It will be not a problem to cut the bottom plate open, but I am afraid the cabinet will be less rigid. Probably have to make reinforcements then, or will this be not a big problem?
@cfy30; Particular those little 2uF caps were up to no good (bad quality). You need to replace these caps with MKT’s or something similar. I’ve replaced them with 1uF caps instead of the original 2uF ones. I think the relays bounce initially because the transformers alone (with no load attached to them) are almost equivalent to an inductive load. Something relays in general do not like. For example, when I tested the softstart with a more resistive-like load (a big light bulb), I did not experience any bouncing of the relays. Further this circuit is very sensitive when it comes to contacting of the switch with the original caps. When the switch made contact a bit too long, it shuts inmediately down after starting. If the relay keeps bouncing there is a good possibility your fuses will blow. This can happen because the NTC’s are already warm. So when it keeps starting up and shutting down, the inrush current will not be dampened by the NTC’s. Resulting in tripping the RCD or blow the fuses. With replacing the little 2uF caps I have never experienced these problems again, even when switching rather inductive loads. To be sure I've replaced all caps on the little PCB.
I’ve seen some nice builds coming by! Good that this tread stays vivid! And complements to the eager builders!!!
I’ve made a little bit of progress myself too .
Now I know my sawguide works perfectly I can cut iron much easier, and more important, without non-straight cuts. I've started with cutting a new backplate for the boards and made the heatsinks for the MJE150033/32 a little bit shorter.
Further I've decided to move the soft start to the front side of my amplifier instead of the rear side. I have had no hum at all, but the soft start was in my opinion still a little too close to the speaker terminals when reconsidering my first lay-out. So I had to make a little plate to mount the soft start PCB to.
It is slowly coming together again. I am still thinking about making new PCB's to mount the TO-3's at since the original PCB's do not fit to the holes in my pre fab new heat sink. And offcourse I don't want to ruin them with drilling in them like there is no tommorow Another option is to hardwire the TO-3's. I've got nice mounting sockets. I am not sure what will be the best solution. Still have to think about that.
My new lay out will be very similair to this:
But I am still fine tuning. Also I've invested in new cooling equipment. At the heatsinks are two 14cm fan shrouds attached. Two 14cm fans will be attached on top of them. Lots of airflow, and more important, less noise. The heatsinks themself are not attached to the cabinet yet, so there still is some room to play and to find the optimal layout.
Another point of consideration are the holes in the side panels. Both side panels now have an ugly 9.2cm hole which they have herited from my the first configuration. I am thinking of mounting two iron 12cm papst fans at each side so the panels stay very strong (because of the iron housing of the papst fans) and offer even more airflow. Offcourse, than I will have to cut a new, slightely larger gap + mount new fan grilles. But that will not be a big problem. The plate which the driving boards are attached to offers in this configuration a very nice air duct to guide the air in and out, without dispersing through the cabinet, but going in and out directly. Have to see if this will help to keep temperature down even more. If not I just have buy two new side pannels Luckaly these panels are not that expensive, but still...
Busy times over here. So further progress is made rather slowly, but will post some pictures when there are new updates
Edit: typo
Michael van den Born - PA4MW - Projects - YouTube
Old 7th April 2013, 02:07 AM   #392
spurlte is offline spurlte  United States
Default 2uF capacitors/softstart
Originally Posted by Kaplaars View Post
@Fix; Cool to see you here, I would love to see another build from your hand!!! :-) You were a big inspiratory to me for building a KSA myself. When I saw your build journals in the other KSA thread, I thought immediately I WANT ONE TOO . By the way fix, how much difference made it for temperature when you cutted the bottom panel open for the tunnel coolers? I have the same cabinet as your, but I use slightely larger cooling tunnels. I am still thinking about making holes for the new tunnel coolers in the bottom plate too, or just using the holes that are already in the bottom plate to gain fresh air. It will be not a problem to cut the bottom plate open, but I am afraid the cabinet will be less rigid. Probably have to make reinforcements then, or will this be not a big problem?
@cfy30; Particular those little 2uF caps were up to no good (bad quality). You need to replace these caps with MKTs or something similar. Ive replaced them with 1uF caps instead of the original 2uF ones. I think the relays bounce initially because the transformers alone (with no load attached to them) are almost equivalent to an inductive load. Something relays in general do not like. For example, when I tested the softstart with a more resistive-like load (a big light bulb), I did not experience any bouncing of the relays. Further this circuit is very sensitive when it comes to contacting of the switch with the original caps. When the switch made contact a bit too long, it shuts inmediately down after starting. If the relay keeps bouncing there is a good possibility your fuses will blow. This can happen because the NTCs are already warm. So when it keeps starting up and shutting down, the inrush current will not be dampened by the NTCs. Resulting in tripping the RCD or blow the fuses. With replacing the little 2uF caps I have never experienced these problems again, even when switching rather inductive loads. To be sure I've replaced all caps on the little PCB.
Ive seen some nice builds coming by! Good that this tread stays vivid! And complements to the eager builders!!!
Ive made a little bit of progress myself too .
Edit: typo
This is funny and maybe you can help. I have the same softstarts as Kaplaars. Yes two, as I am thinking of building two mono blocks. The little softstart PCBs are printed as 2uF but 22uFs are soldered in its place. What gives? Will it still be advisable to replace the 22uFs with 1uFs?
Old 7th April 2013, 10:03 AM   #393
Kaplaars's Avatar
I have two too (one for spare) . Indeed funny because the one that is used currently in my KSA had a 2uF MKT attached, but the other one had a normal 22uF capacitor soldered on this place. Probably they have had more problems, and tried to find a different solution. 22uF could work but probably only because a normal cap has higher ESR so switch bouncing is more dampened. I choose to lower capacity. I saw that similar like circuits using the same Ne555 are using an 1 uF capacitor too. That works for me. I have not tested the circuit with the 22uF capacitor. Have you experiented with it David? Do the relais bounce when you switch the transformers alone?
Old 7th April 2013, 02:43 PM   #394
necdetyetisgen is offline necdetyetisgen  Turkey
My Krell finished Only Krell logo will write on it. Kaplaars thank you for this forum. I want to make a new one again. They will be mono and mono. I have a meterials.
Old 7th April 2013, 04:17 PM   #395
Kaplaars's Avatar
Woooowie, very nice, I like the VU's!!! Was it easy to add them to the amplifier? Would love to have VU's too. Also I have to say that I realy love the woodwork, that is a very nice piece of furniture!
Old 9th April 2013, 01:59 AM   #396
Default SoftStarts
I am fishing in Michigan on the Maumee River for walleye just south of Lake Erie. I will be home soon and I will experiment with soft start and transformer alone. Darn Kaplaars, you work fast. I will also test with a 100 watt light bulb before switching to 1uFs.
Old 9th April 2013, 12:25 PM   #397
Yet it was easy. But you must cut front panel. I cut it with cnc machine and I bought
from ebay Vu Meter Driver Board Stereo with Backlite Voltage Output | eBay and 1pcs Classic Lake Blue Taiwan High Precision Vu Meter DB Level Meter | eBay
I will do left and right edge with woodwork for furniture perhaps center side to.
I have a problem. While all 47.000 mf condancer is emtpy I open the ksa 100 .The soft start role has spark. If 47.000 mf condancer is full stop and again start no spark.
I think it is a big problem. I used Class A Power Delay Soft Start Temperature Protection Board 110V 220V | eBay and 2 x 1000 va transformer.
Old 9th April 2013, 05:49 PM   #398
I find mistake ntc 's broken I changed them.
Old 14th April 2013, 04:01 AM   #399
I checked both soft-starts with the 22uF caps instead of the 2uFs and I, without load, did not experience any bouncing. But I did notice that when I momentarily closed the switch wires, it turned off when it wanted to turn off. Will try later with a load of some sort.
Old 14th April 2013, 06:05 AM   #400
Jozua is offline Jozua  South Africa
Michael/Kaplaars
The latest layout looks excellent.
Consider putting the heat-tunnels on a base plate with opening at the bottom of the amp that will enable you to easily replace a fan without having to remove the whole heat-tunnel. With regular use fans do get noisy or need to be cleaned.
Jozua
Stolen Trademark Amplifier from Jim's Audio on EBAYHide this!Advertise here!
Jim's Audio Goldmund Telos 390 clone Tyimo Solid State 18 7th January 2018 08:46 PM
Jim's Audio F5 power supply board Hikari1 Pass Labs 35 4th December 2013 10:41 PM
Jim's Audio F5 referenced kit. HiVi Guy Pass Labs 21 22nd November 2012 10:24 AM
Stolen items? kctess5 Multi-Way 14 23rd February 2012 10:02 PM
