Stolen Trademark Amplifier from Jim's Audio on EBAY
Old 13th August 2012, 04:55 PM   #301
neychi is offline neychi  Croatia
Originally Posted by spurlte View Post
No, these are new ones from PacificSemi.com. They have 2sa968, but they sent substitutes, 2sa1302/2sc5200, for your 2sa1011/2sc2344 and I was taken aback by their physical size, T0-3P, compared to T0-220. The substitutes are 150watts with a base current of 2.0A at 200Volts. Much stronger, no?
Yes, much stronger. 2sa1302/2sc5200 (for output stage) are definitively not a substitute for 2sa1011/2sc2344 (for driver stage). 2sa1011/2sc2344 have only 25W. And one more thing, 2SA1302 is complementary with 2SC3281 and 2SC5200 is complementary with 2SA1943.
Kind Regards
Old 13th August 2012, 05:51 PM   #302
spurlte is offline spurlte  United States
Default Thanks
Thank you. I saw that on 2sa1302's specs sheet. What was pacificsemi.com thinking? Funny thing, I now have a bunch of good 2sa968 from various places.
Old 13th August 2012, 08:02 PM   #303
send them back demanding a full refund.
regards Andrew T.
Old 13th August 2012, 09:46 PM   #304
Default Bad Buy
Yes, I agree. AndrewT, I am learning this whole new field--purchasing thru electronic project building. I said earlier that I am a retired nut who is watching other retirees dying left and right because they don't know what to do with themselves. " If you are what you do while working, who are you when you are not working?" If I lose a few dollars while learning this whole enterprise of electronics, so be it. I just ask for your patience.
Old 13th August 2012, 11:20 PM   #305
homemodder is offline homemodder  Portugal
I wouldnt purchase any of the transistors on those pics, you should start the project troublefree, they are all cheap chinese fakes.
Old 21st August 2012, 05:07 PM   #306
a.wayne is offline a.wayne  United States
Sin Bin
Can outputs MJL21193, MJL21194, be substituted with MJW1302/3281 ..?
Old 21st August 2012, 05:37 PM   #307
the KSA started with MJ15003/4.
I would estimate that the MJL21193/4 are much closer to the originals than the MJW1302/3281
regards Andrew T.
Old 21st August 2012, 05:40 PM   #308
Sin Bin
Yeah figured ....
Old 21st August 2012, 07:59 PM   #309
Kaplaars is offline Kaplaars  Netherlands
Kaplaars's Avatar
What is actually the motivation for substituting the MJ15003/4's with different devices? The MJ15003/4's have better thermal conductivity than TO264 devices which is pretty critical for this project. They are also almost everywhere available. Offcourse they have lower Ft, but I would consider that as a advantage, this will reduce chances of oscillation a bit more. Can someone explain which specific parameters are important and why?
Michael van den Born - PA4MW - Projects - YouTube
Old 21st August 2012, 08:13 PM   #310
Sin Bin
I believe the current EBAY kit is using MJL21193, MJL21194 .....
Stolen Trademark Amplifier from Jim's Audio on EBAYHide this!Advertise here!
Jim's Audio Goldmund Telos 390 clone Tyimo Solid State 18 7th January 2018 09:46 PM
Jim's Audio F5 power supply board Hikari1 Pass Labs 35 4th December 2013 11:41 PM
Jim's Audio F5 referenced kit. HiVi Guy Pass Labs 21 22nd November 2012 11:24 AM
Stolen items? kctess5 Multi-Way 14 23rd February 2012 11:02 PM
