Stolen Trademark Amplifier from Jim's Audio on EBAY
Old 8th July 2012, 10:22 AM   #141
dhbiker is offline dhbiker  Slovenia
congrats! was wondering if it works or not
p.s. if the heatsinks get too hot you can try buying some fans with higher static pressure
Old 8th July 2012, 02:52 PM   #142
Kaplaars is offline Kaplaars  Netherlands
Kaplaars's Avatar
Thanks for the replies guys!!! It is so nice to see it work.
Like you all can see in the previous pictures the setup right now is far from ideal, but luckily it worked to test the lot :-). Due to the bad wiring I was very suprised that there was no audible hum. Especially grounding is far from ideal right now. When I connect the oscilloscope to the speaker outlets, little hum arises because of a groundloop that is formed (the oscilloscope is grounded aswell). That is also why I have to measure very carefully and one channel at a time because both channels are not galvanic separated in the oscilloscope. Momentarily the only grounding point is at the chinch connectors from the pre amplifier. So at the end of the signalcables. I use an Accuphase E204 which I restored last year (yes I am very spoiled with that amplifier haha) as pre amplifier. The signalcables are very thin la liquorice lace, long (almost 5 meters, so you can imagine how thin the shielding and thus grounding cables are) and cheap but it seems that this cable was usable for testing. It is almost unbelievable that there is still room for improvement while it sounds so good allready. There is a reasonable chance the amplifier will be even better because in the final setup the cables will be far more shorter and thicker.
@David (Spurtle); you're welcome! I did not mentioned the missing track till I tested it. When I relooked to some of the pictures which I made at the start of the build I saw the track was really missing.
Dean (Neychi) has a blue version of Jim's boards. Dean showed me that his version has the track. There is a good chance that, when you have blue ones, this track is on your boards aswell.
When using both channels the heatsink gets hot, while when using one channel the heatsink does not seem to care. I would estimate about 60 degrees @ 400 mV bias when using both channels. From the other hand room temperature (@loft) is exceptionally high right now. Very nice wheater in Holland. The trannies at the intake of the tunnel are pretty cool (50 degrees or so), but at the outtake the trannies are hotter (would estimate 60 / 65 degrees) which AV werk mentioned earlier in this threat. So I think that it will exceed the 75 degrees when mounted in the cabinet, fans on less speed and higer bias. When that is the case, I think that I will change the thermostats to 85 degrees devices. But I have to measure temperature when mounted in the cabinet. Maybe I can borrow a nice temperature meter from University (they have very nice Fluke equipent over there ).
The dummy is capable to handle 2x 200 W @ 8 ohm, but when I turn the fan on 250 W per channel is not really a problem .
@Jozua: I realy hope temperature does not get out of control. Especially since I planned to mount the driver PCB's on top of the tunnel coolers. Between the tunnel coolers and PCB's I will mount a metal plate to protect the PCB's a bit from the heat. From the other hand this makes radiaton even harder. Altough I have to say, the tunnel coolers seem to radiate very little radiate heat when I sense the radiation heat from 4 cm distance. It seems that almost all the heat is transfered through the cooling tunnel by the fans.
@ A. wayne; there is a good chance Jim does not know. He has never mentioned it to me. I will sent him an email, maybe he can inform former customers this way also
@ David (AVwerk): Thanks for the tips!!! I am very gratefull for this tips. I did not really know how to test it next to the measurement I mentioned before. I will certainly post some scope pics while performing this tests! But that have to wait a few days till I have attached the leads a bit better and mounted the PCB's on top of the tunnel coolers. Everything is a bit loose connected right now, so attaching the probes and making pictures is a bit tricky.
That is by the way why I stopped using the amplifier right now (which was very hard, I wanted to make a little test, but had to play this record and that record... and before you know it is 3.00 p.m. hahaha). But I am afraid a cable will detach and make short circuit. Happend once when I was restoring an Luxman LV-103, be very careful when using cable clips, they can detach very easy
@ Dean, haha will do
@ DH biker: Will consider that! I still have to tink about a nice way of fancontrol and find a good bias vs. heat vs. noise ratio.
Old 8th July 2012, 04:08 PM   #143
spurlte is offline spurlte  United States
I got a hold of Jim's Audio and his reply is "Dear sir,
Thank you very much for letting us know of the error. I am myself surprised that there is no connection there. On inspection it seems a gerber error that waw not there in the previous version. If you look on the top side, the disconnected MJE15003 left-most pin should be connected to the track running below it, but the link is missed. I will check with the PCB vendor why this had happened. And I will absolutely revert to the correct one in the next spin of production. Thank you again for the information. I appreciate the diyaudio forum have made this a more perfect board.
Best Regards,
JIMS AUDIO"
Old 8th July 2012, 04:43 PM   #144
neychi is offline neychi  Croatia
No Michael, I have the red ones like you but with different silk print on it. Look at the picture. That blue one which I sent you, wasn't mine. This red it is.
Kind Regards
Old 8th July 2012, 05:10 PM   #145
Kaplaars's Avatar
Good job David!!! I also got a reply from Jim:
Thank you very much for building the boards with patience and shared your experience with other people. I have checked the board, and it seems to be an error that happened during PCB fabrication, since in the first log of boards ( I built two logs, and the first log was done in 2007 - 2008) there is a link from the track ( right below the transistor MJE15033) to the base lead of this transistor. I need to check with our PCB vendor why this happened. But I thank you for letting me know this otherwise I thought the board is as good as it has to be.
Nice that this mystery is solved :-)!
By the way David, there is another thing you have to take into account. Around the holes which are meant to attach the MJE15033/32's to, there is a conductive ring:
When you attach a non isolated / non anodised heatsink, which means your heatsink electrically is conductive, chances arise that your heatsink will make short circuit due to a connection with these holes. This holes are connected to the the collectors of all MJE15032/33 devices. Short circuit between the collectors is something you definetely don't want, because your power lines will make short circuit also (V+ and V- are attached to the collectors). So you have to isolate the heatsink from this rings aswell, or use an isolated heatsink. I took no risk, so I chose to remove the conductive layer on the surface around the holes in the front by drilling very carefully the little conductive surface away. Worked like a charm :-).
@Dean: Aha, so you have the red ones too. I thought the blue ones were yours :-D. Hmm, maybe Spurtle is lucky and have his PCB's the tracks aswell.
Old 8th July 2012, 06:54 PM   #146
you can still DIY it since you already did the amp :P i think i have the schematic somewhere... i'll look for it and upload it if i still have it
Old 8th July 2012, 10:29 PM   #147
zeca2011 is offline zeca2011
Smile Hello friend, thanks for these details. I have the same PCB, and did not see this det
Wow it is realy quiet here. But not in Wageningen, Holland were a KSA-100 is born because, yes friends........ IT FINALLY WORKS!!!!!!!
I was realy nervous when powering it up. I've hooked the dummyload together with a Zobel network to the outputs. This was it, was al the effort I've made going to pay off, or did I make a nice piece of expensive firework. With a fire extinguisher in my left hand and with my right hand across the dial of the variac, I slowly powered it on. Hmm, no fireworks... that seems good. And It kept good!!!
But there is a but friends, I got no bias to one halve of the MJE15004's. I discovered a little mistake on Jims boards, there is missing a little track from the emitter of the middle MJE15032 to the MJE15033 compaired to the original. So I had no bias on connection DRIVE P1. But that was fixed easily with a little wire:
After fixing this, there was also current from DRIVE P1. Everything seemed to go OK so I pressed the proverbial gas pedal a bit more ;-). Freakin unbelievable how much power it has. I've measured 40 VAC max output across 8 Ohm load!!! I was able dial the DC offset to 0 mV very easy. Bias spread is about 10 mV across the different TO-3 devices. Not bad, I since I have not matched the devices :-).
After some testing (it was 2:00 p.m. already) it was time for some music! It's is unbelievable how it sounds, I try to be as objective as possible, but it is so dynamic, so much power. No hiss, no hum, nothing!!! I've set bias to 450 mV right now. Fans are running full speed right now (fan control is not finished yet). For Dutch standards today is pretty tropical, it is about 26 degrees outside and here in house it is almost 33 degrees. But despite of that, the tunnel cooler gets mildly warm.
Glad that it works, and VERY VERY happy that it sounds even better!!!!!!! But there is still a lot of work to be done, because now I know it works I can and thus still have to mount the lot in the cabinet :-)
Old 8th July 2012, 10:46 PM   #148
Default KSA100
Hello kaplaClick the image to open in full size.ares
Thanks for the details of the PCB Jims, had not seen.
I'm riding slowly.
Great project, I hope to get close, rsrsrsrs.
Best regards.
Old 8th July 2012, 11:06 PM   #149
Kaplaars's Avatar
No problem Zeca ! Nice to see your build is progressing too!!
Made a little bit of progress this evening. In the original Krell there is a little PCB which functions as groundplane. This little groundplane is attached to the cabinet. It also contains two 10 Ohm resistors which are connected between ground and the capacitors. Unfortunatelly I can't make PCB's. Haven't got the chemicals and a little etching tank to oxidise copper into Cu2+ and thus etching nice tracks. But....... Kaplaars is maybe not that old but Kaplaars knows about old school So I scraped little tracks into FR4 (glass loaded epoxy) single sided PCB plate. I coated the copper with some tin. Results could be worse
Old 9th July 2012, 12:20 AM   #150
Default Red PCBs
No luck here and it just adds to the fun I am having building this amp. I have the older Red PCBs, but it is easy to fix, thanks to your eagle eye. I have the bolt bushings and mica film to make the connections nonconductive. Should I also apply white grease? I understand that these MJE15032/33s do not get too hot. So they really don't need a large sized heat sink?
Stolen Trademark Amplifier from Jim's Audio on EBAYHide this!Advertise here!
Jim's Audio Goldmund Telos 390 clone Tyimo Solid State 18 7th January 2018 09:46 PM
Jim's Audio F5 power supply board Hikari1 Pass Labs 35 4th December 2013 11:41 PM
Jim's Audio F5 referenced kit. HiVi Guy Pass Labs 21 22nd November 2012 11:24 AM
Stolen items? kctess5 Multi-Way 14 23rd February 2012 11:02 PM
