#241 |
David, don't mess up with transistors of suspicious origin if you can't get the real mccoy. Get 2sa1011/2sc2344 like I told you. Mouser is no guarantee that these are the original transistors. A few years ago I ordered via RS Components Toshiba's 2sa968/2sc2238 and got Magnatec. They work fine but these were actually 2sa1011/2sc2344 transistors with polished front and re-printed logo and product labels. I've made a comparison. I even went well, but their price was pretty high and I could get a two original transistors for price of one. Just be careful.
Best Regards Last edited by neychi; 28th July 2012 at 12:31 PM. |
#242 |
What a 2012 Olympian opening show! I have here a post from AudioKarma
Toshiba 2SC2238 + 2SA968 counterfeits? [Archive] - AudioKarma.org Home Audio Stereo Discussion Forums It talks about 2SA1837/2SC4793 as substitutes. I see that the only difference is that the Ic=1A. The 2sa968's Ic=1.5. Is this a big difference for the KSA 100? |
#243 |
I could not agree with Dean more
I have very bad experiences with cloned / fake transistors. Repaired a Denon PMA-920 once. Replaced the original Sanken outputs for ISC's. 5 seconds full power at the dummy and BOOM. Sliced the trannies open, and.... well see for yourself, compaire the dies (left ISC, right good ol' Sanken):That little joke made the repair even more costly, could replace the drivers again, and now the biastransistor and emitterresistors were broken also. |
#244 |
2SA1837/2SC4793 are not direct substitution, 2sa1011/2sc2344 are.
Semiconductor Substitution List Edit: Michael, congratulation! Excellent Fluke
Best Regards Last edited by neychi; 28th July 2012 at 12:39 PM. |
#245 | |
#246 |
neychi, I talked to the owner of this electronic components store in New Jersey, USA
2SA1011 pdf 2SA1011 datasheet PNP Epitaxial Planar Silicon Transistor - High-voltag Switching - AF Power Amp - 100W Output Predriver Application 2.51735 Transistors Bipolar Silicon PNP Power Transistors American Microsemiconductor 2SA1011 available a as I found the 2SA1011 but not the the 2SC2344. I called and got the top man himself. He took all my information regarding the 2SA968/2SC2238 and the 2sa1011/2sc2344 and said he will get back to me shortly, at least by Monday. You guys are my guardian angels and I owe you a cold beer. And I also see the specs for the 2sa1011 where the Ic-1.5A. Nice |
#247 |
Best Regards |
#248 |
Started on putting the Power Supply components into the case. Boy, it is HEAVY. Now when I go to second hand stores and see used amplifiers, I just pick it up to see if it's heavy. HA-HA.
#249 |
Wow, when you see it in this perspective those transformers are really huge! I like them. Will that become the PSU-box for the KSA David?
Haha, you better prepare, it will only get heavier Mine is almost like a boat anchor when lifting it up. But hey, great excuse to quit my fitness subscription See it from the bright side David after lifting the KSA a dozen of times you will gain the same muscles like Arnold Schwarzenegger had in his glory days ![]() Well going to sleep now, but, to quote Arnold 'I'll be back'
#250 |
Wow, those transformers are HUGE!!!
. How much do they weight? what are the spec for them?
| about ksa-100 | dimis | Solid State | 3 | 6th February 2005 07:55 PM |
| Help for repair my KSA 100 | Alex helge | Solid State | 76 | 23rd October 2003 03:38 PM |
| Bias KSA 100 | Alex helge | Solid State | 1 | 24th August 2003 11:19 AM |
| Krell KSA 100 | Alex helge | Solid State | 2 | 24th February 2003 03:05 AM |
