I was drawing a little experimental MOSFET amp. Could you check it? What do you think about it? Thanks Tamas |
#3 | |
I had a goal: to get a stabilized Bias, and an easy structure. I also would like to use VERY BIG MOSFETs that is why you see the 22nF capacitors at the gates, as these are just there to mimic the BIG gate capacitance... also the stages are relatively easy to modell (and also measure) separately, so compensation could be easily calculated/ tryed. cheers, Tamas |
#4 |
Hmm your picture says 200v rails, that is serious power- audio – or PA- or mains power regeneration....., I personal would not want to hook anything like that up to my domestic speakers for fear of a “back to the future” moment!
#5 | |
Yes, you are right! I just wanted to write there some big numbers for the theoretically max possible MOSFETs available in N and P version (200V P MOS is the max I have found) If I ever build that I will start with some +/-30...50 V rails cheers, Tamas |
#6 |
If you like prototyping things first, I would try some thing like this first, separate the gain from the current buffer, get the output working first, then the gain, then together, and then with loop feedback, and then add more mosfets and stuff like your original circuit. You will have probs with your buffer stage opamps when they go open loop every time the mosfets turn off, causing worse crossover distortion. Can fix a bit with diode in feedback loops probably, look at precision opamp circuit with 2 diodes iirc, has sorted same problem already.
modded (ehem) your circuit to something a bit easier to get going (hopefuly) h |
#7 |
If this is your first amp, something even simpler might be a better place to start. Simple doesn't mean it won't be good, in fact it might be better and you might want to go in a different direction than what you have shown above.
I'm thinking single NE5532 driving a pair of output devices with simple bias into Class AB with diode string. I'm sure somebody has a circuit for this already.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#8 |
William Chatter has some FET bias servo designs in Audio Amateur and Audio Express, and a KT88 servo design as well.
Yours is similar, but he has all the details worked out. The easy way to do it is to drive ground with the FETs, and take the output from the transformer center tap (QSC and Hafler style). Chatter uses a suspended supply.
Candidates for the Darwin Award should not read this author. |
#9 |
Those opamps also need input protection, diode or something.
#10 | |
Any link to the William Chatter servo FET amplifier schematics? I become very interrestd :-) Thx, Tamas |
| Looking to find 2SK343 & 2SJ99 MOSFET | Eimac | Parts | 4 | 14th June 2009 10:12 PM |
| Wanted: H&H MosFet V800 Power Amp | SkipperSims | Parts | 4 | 8th November 2008 12:40 PM |
| can someone help me on my first mosfet amp? | happyboy | Solid State | 2 | 23rd January 2006 04:12 PM |
| Mosfet amp problem, Slone amp | 5th element | Solid State | 14 | 22nd March 2004 11:03 PM |
| SOZ PSU & Fairchild MOSFET | MEGA-amp | Pass Labs | 3 | 6th November 2003 04:14 AM |
| Page generated in 0.14094 seconds (64.98% PHP - 35.02% MySQL) with 11 queries |
