I have put into service pure class A amp based on the following schematics. Assembled point-to-point, sound is amasing. Gives impression of a "direct wire". I compare it with SE 300B based amp. Similar sound transparency, but overall is better.
I understand real problem with getting RD100HHF1 transistors, but I gues other good ones will go. |
#2 |
Can VT3 be substituted with 2SK170BL? And VT1/VT2 with equivalents from Fairchild? I am asking since I may be able to try these with substitute parts. Thanks.
Sam |
#3 | |
Most of all sound affected by the output cap design (I used Jamicon WG series, but Panasonic FM 1000uF could be even better), and big polypropylene shunt is obligatory. Be shure, sound will pleasantly surprise you. One possible difficulty will be a good preamp, tube one with no less than 20dB amplification will fit. My solution for preamp I posted at Pass forum The 50W version of Zen9 Last edited by VladimirK; 17th February 2011 at 12:23 PM. |
#4 |
Sorry I forgot to ask earlier but how tight and articulate is the bass; mids and highs should be as good as tubes, from your report.
Sam |
#5 | |
With 50W Zen9 bass is also good with Aleph CS being active, but without it, the highs are close (almost) to the Follower, but the bass of Follower is noticably better. |
#6 |
Here are some fotos of the Follower, point-to-point soldering
#7 |
I have measured frequency dependent output impedance of this follower (mOhms on the vertical axis, and Log10 F(Hz) on the horizontal), and also of two modifications of 50W Zen9.
Curve 1 - present follower Curve 2 - 50W Zen9 with increased NFB, voltage amplification near factor 2, without current source modulation Curve 3 - 50W Zen9 with standard amplification factor 5, current source modulation is active Variants 1 and 2 are close in middles and highs reproduction, but the bass is the best with follower |
#8 |
Are V1-V3 9v zener diodes? And are HL1-HL6 LEDs (what colour, voltage drop)? 1KVA transformer! What concessions can be made in this costly component? It will be nice if you can make a full bill of materials, indicating modern alternatives. Thanks.
Sam |
#9 |
Wow, what a wonderful mosfet the RD100 is! But I can't see circuit improvement that will solve the 99-Follower's problem if ordinary IRF mosfet is used.
How come this RD100 is not popular? (at least unknown to me) |
#10 | |
HL1-HL6 are the red light diodes, with near 1,8V voltage drop on each. They represent simplest, but extremely fast and low noise shunt power supply for VT3-VT4. As yuo not, I do not use here electrolytics as well. Using VT3 instead of resistor, makes CCS composed by VT2-VT4 more close to an ideal one. 1KVA transformer looks like a joke, but I have not managed to avoid electro-mechanical trafo bussing with smaller ones, since my aim was an absolutely pure backgroung. If you manage to avoid buzzing under 4A load with smaller trafo, that will be your benefit. |
| Preamp for Power Follower 99 | Ant1Xr1st | Solid State | 7 | 9th March 2010 06:28 PM |
| Hot Follower 99 | MEGA-amp | Solid State | 25 | 7th March 2010 08:00 PM |
| Power Follower 99 | barossi | Solid State | 0 | 10th July 2006 11:06 AM |
| power follower 99 help | renjiish | Solid State | 3 | 20th November 2004 09:30 PM |
| Quality in a Cool Follower 99 | GMS | Solid State | 12 | 19th March 2003 04:52 PM |
| Page generated in 0.20751 seconds (48.15% PHP - 51.85% MySQL) with 11 queries |
