Old 16th February 2011, 08:14 PM   #1
Default ebay amp L20 power amplifier
somebody already asked about this amp in the chipamp forum
Has any one tried this l20 - 350 watt amp
but the thread was not moved or reopened, so I am asking basically the same question: Has anyone tried this particular mono amplifier or something similar?
What does it look like to you?
here is the ebay-item number to one of the auctions:
120646650832
it looks like this:
( ebay-seller: along1986090 )
(I am posting a picture of this because eBay auctions do not stay online very long and I often ran into threads with dead eBay links which is frustrating)
Any thoughts on this one? Usable with a good PSU and some cap replacements?
thanks
regards
meko
Old 17th February 2011, 08:30 PM   #2
Hmm, the amp seems not so popular
alright... well, among many other amps he also sells some assembled "NAP 140" clone boards:
along1986090 items - Get great deals on 2pcs Classic NAP 140 CLONE mono power amplifier board items on eBay Stores!
I'd be using the supposedly good gigawork NAP140s, but they only deliver 70 watts into 8 Ohms.
I need a rather clean dual mono power amp set with approx. 100...200W into 8ohms per channel.
any suggestions?
thanks again
Old 26th April 2011, 05:05 PM   #3
nrg2009 is offline nrg2009  United States
looks like an interesting nap140 clone. I would guess someone has bought this and tried it.. I may be the first!
Old 22nd May 2011, 12:49 PM   #4
dickl is offline dickl  United States
I have bought a couple of preamps from them and am impressed with the company and the products. Very good service and very good value. Have not experienced the amps.
Old 1st July 2011, 07:25 AM   #5
rfj5106 is offline rfj5106  United States
Default L20 project
I just finished building an amp using the L20 boards with dual Plitron 40-0-40V @ 2.75 amps and 6 x 10K uF capacitors per channel in the power supply. I also used a soft start module and a speaker protection relay board for start-up. I had pipe dreams of using peltier devices which would allow me to get by with less heat sinks but my experiments with peltier devices were failures. So I have a thermal switch set to 85 degrees Celsius that will cut the AC if the temp by it reaches 85. So far the heat sinks have got quite warm but not too hot to touch. The maximum length of time I have had it on is 2 hours. I don't feel like tempting the fates by leaving it on.
How does it sound? So far quite good. It was built to replace an aging Yamaha M-70 that been in the shop 3 times in the last 2 years. My math says it was cheaper to build than repair. The L20 to my ears sounds slightly more detailed than the M-70 so I am a happy camper about this project although I should have had bigger heat sinks.
I am going to try to insert a picture of this project. My handy work is not so handy! I call this project the DB amp, DB stands for Dog's Breakfast in honour of ny chaotic wiring.
Richard Jenkins
Old 12th April 2012, 10:23 PM   #6
looks still nice!!
Old 18th April 2012, 03:21 PM   #7
ljm_ljm is offline ljm_ljm  China
Thank you for your use me to design the amplifier.
. If you have any questions, you can mail. ljm_ljm@foxmail.com
L20 in constant updates, to the stability of the better version, and better performance.
The current version is VER 9. L20 USES blue PCB materials. Blue is genuine.
Notice that there is some other color is probably pirated products.
Old 18th April 2012, 09:25 PM   #8
Thanks,
i bought this one on ebay:
http://www.ebay.nl/itm/200723842622?...84.m1439.l2648
best regards, and thanks for your help.
I probably will email you.
Are 2 of these:
Aluminum HEAT SINK FOR LM3886/TDA7293 Amplifier Board
professional QUALITY METAL Radiator 140*81*44mm,0.48kg
heavy enough?
Old 18th April 2012, 09:43 PM   #9
N-Brock is offline N-Brock  United States
N-Brock's Avatar
You may have found this out while experimenting, but using peltiers would actually make more heat that needs to be dissipated.
-nelson
Old 19th April 2012, 08:18 AM   #10
Default hi nelson
What would you recommend for a cooler??
modu
this one has heatsinks on the outside..
best regards,
marco
Has any one tried this l20 - 350 watt amp srinath Chip Amps 1 12th January 2011 06:10 PM
LYNX Power Amp non-authorized clones on ebay Jan Dupont Solid State 22 24th March 2009 04:10 AM
2sc5200 & 2sa1943 power tr. forsell on ebay Pineng Swap Meet 0 23rd July 2008 10:56 PM
FYI: FS on eBay - Analog Audio SONATA 300B SE Power Amp cartman Swap Meet 0 19th March 2007 08:05 AM
For Auction on ebay: Precision Power Tube Driver TD 2150 amp BuzzerBro Swap Meet 0 4th October 2005 07:28 AM
Page generated in 0.12867 seconds (74.65% PHP - 25.35% MySQL) with 11 queries
