Old 16th February 2011, 07:06 PM   #1
codegen is offline codegen  Norway
Send a message via MSN to codegen
Default Leachamp with thermaltrack outputs
Hi all!
Ive built leachamp using NJL4281/NJL4302 outputs, and using the internal diodes in these for thermal sensing.
But, the internal diodes are not exactly like 1N400X that leach specifies, and i have to turn the trimpot almost down to 0R to get it correctly biased, is there a way to fix this. Also, im using 6 outputs, maybe i should be using all 6 internal diodes also to get higher accuracy?
Using LTSpice, it seems that changing R25/R26 from 1k to 1k2 might fix my problem? Any inputs?
Are there any dilemmas using 0R22 instead of 0R33 for the output resistors?
Also, from what i understand, it is only stable down to 2 ohm with MJE15032/33 drivers, is there a possibility to make it stable even down to 1 ohm? (off course i have to increase the number of outputs..)
Build Thread: LME49810 + 8 Pairs ThermalTrack Adrculda Chip Amps 49 20th February 2012 03:30 AM
Need a good preamp for the LeachAmp roger-k Solid State 15 9th September 2006 08:10 PM
Preparing to start construction on LeachAmp, all I need is wire? wigginjs Solid State 1 23rd June 2004 08:42 AM
Help with selecting PS Caps (for LeachAmp) FromageTheDog Parts 8 7th February 2004 08:10 AM
Aleph30 vs LeachAmp: PS Fusing swede Pass Labs 2 13th July 2002 03:56 AM
Page generated in 0.06644 seconds (66.95% PHP - 33.05% MySQL) with 10 queries
