Old 16th February 2011, 08:37 AM   #1
GoranB is offline GoranB  Poland
GoranB's Avatar
Default PF 99 years of happines
I have built PF99 by Andrea Ciuffoli about 5-6 years ago, also his tube preamp which im useing like gain source. Durring these years i was changeing many other amplifiers, in general they were push-pull, but also tube amps.
After week or two, i was always conecting PF99 again to my system. I still cant find some amp which can "gave" more music then this design of Andrea.
I would like to exchange sound impressions (PF99) with people on this forum.
Old 11th April 2011, 08:20 PM   #2
arche13 is offline arche13  France
Good evening
I also have a pf 99, with préamp aikido with 6n1p and 6 o'clock 30,
In exit(release), my surrounding wall(speaker) of klipsch. Trés good sound
My PF99 is built with the original plan and IRF150N.
Your is he(it) built with the original plan?
What modifications have him(her) to bring you?
Cordially
Old 12th April 2011, 05:40 AM   #3
Sometimes I see replies from PF99 builders, that they are not satisfied, in particular, not enough bass.
Good solution, confirmed by practice, for solving it - put 20pcs of 1000uF good quality caps, and decent polypropylene shunt to them.
Another point - an issue of the preamp. It must provide high sound quality with voltage amplification 20-30dB and low output impedance (tenths of Ohms in case of the PF99 based on IRFP150). I do not think these requirements are easy fulfilled by a tube preamp.
Old 12th April 2011, 06:10 AM   #4
Hello Vladimir
It thus makes 20000µf by channel(canal), more the shunt of 50µf, what typifies of préampli it would be advisable?
Old 12th April 2011, 06:14 AM   #5
Hello Vladimir
I am going to try soon with 6:30 am in SRPP it préampli!
Assembly(Editing) of internet with ra and rk 170 ohms assembly(editing) of Dilinhger
Old 12th April 2011, 06:52 AM   #6
I have tested and can recommend this preamp schematics, for PF99
No NFB Headphone/Pre Amp
Old 12th April 2011, 12:03 PM   #7
GoranB's Avatar
Good evening
Cordially
Hello arche13,
In my PF99 im using IRFP240
Current 3A per chanell
Voltage 34V regulated
Output capacitors SPRAGUE 4700uF/63V, bypassed with 16uF WIMA
PS capacitors -2 x 8200 uF/100V Nichicon
Two power transformers, one per chanell 34V/400VA
electrolitic caps in the circuit: 470uF/63V - Elna silmicII, 220uF/63V - Vishay low esr.
Ressistors are the ordinary cheap ones.
Vladimir gave me the same suggestion, cap-cluster, i still didnt try that mod. But for sure it will result with better sound.
My preamp:
gain stage: PCC88
catode follower: 12BH7
catode biasing of the gain tube - one red led.
output caps: 2x100uF/400V - Siemens (per chanell)
PS caps 4x68uF/385V - ROE, 220 uF/400V - Rubycon
AC heathed
The preamplifier is absolutely quet.
Sound warm, detailed, but kind of slow.
The best result with PF99 i reached, when i connected CD player output directly to PF99 inputs. Without preamp.
Vladimir designed preamp which could be implemented with PF99.
Thread: "NO NFB HEADPHONE PREAMPLIFIER" (something like that)
I have intention to build his design in near future.
Best regards
Goran
180 pF capacitor and other questions dosilegecko Tubes / Valves 35 26th March 2010 07:53 PM
Pf 99 cominup Solid State 0 23rd April 2007 08:39 AM
Questions on 6H30 simple PF? pengboon Tubes / Valves 6 30th December 2005 03:40 AM
****Silver wire 4n 99.99% 0.5mm x 25m for sale **** zanash Swap Meet 7 3rd July 2005 07:55 AM
Page generated in 0.10623 seconds (70.80% PHP - 29.20% MySQL) with 11 queries
