I wanted to share what I've been working on for the past year or so. I been following the "The very best amplifier I've ever heard" (TVBAIEH) thread and it got me thinking. The best amp I've heard is the Allison variant that several folks hear helped with. When I say helped with, they came up with the scheme, I built and tested it. I want to acknowledge Keantoken, PaulBysouth and KenPeter who all helped immeasurably. You can read about the development of this amp on the following: (this configuration starts at post #308) Simulation Analysis of several unique Allison-based output stages.
I've compared this amp against a triple emitter follower and a nice 50watt Rotel amp. I can't claim to have heard all the world's great amps, but, this one is just a bit smoother than the others. I really enjoy music that features the human voice, from opera, to Frank Sinatra and everything in between. This amp helps those voices shine! I know these opinions are subjective, so, that's what you get... To test the amp in simulation; I've compared it to Bob Cordell's Triple emitter follower Figure 3.10 on page 65 of his book. Using Bob's model files and Thd setup, I've put together the Figure 3.10 as a baseline and used the front end of this amp to graft the modified Allison on as the CAS. I then ran each in simulation at various input voltages to get a picture of THD. A note on the modified Allison, it runs in class A up to about 16watts into 8 ohms in this configuration, but, it can be easily adjusted by changing out one resistor. Got to go, a bit more later. |
#2 |
Can you run other simulations?
I'd like to see HD2 to 9 at 10khz, 20khz and 50khz (at just 1W would be fine). Besides, I'm more interested in your listening opinions than the sims. Which which amplifiers (or better, output stages connected to the same frontend) did you compare it?
The response of the inner ear extends to at least 200khz - Dr W. Tempest |
#3 | |
I have been using an LME49811 for the front end on all my test amps. It's on a separate board that plugs into the CAS board, so that I can swap out different typologies easily. In all I have built 7 or 8 different CAS typologies - some minor variations on others. I compared it to a pure Class A Allison, a double emitter follower and a triple emitter follower. The guys from National say that the 49811 contains pre-drivers, so that a triple isn't required, but, who knows? In comparison to the double emitter follower with the same type of driver and output transistors, re resistors, etc. the modified Allison made the voices more natural, more open and less strident. It's tough to describe these things, the double emitter follower sounded great, the modified Allison just sounded better in comparison over many hours of listening. Ken |
#4 |
Oh, so you are the guy that Anthony talked me about.
Same output transistors? Now much NFB?
#5 |
#6 |
I meant how much NFB? Same in both cases?
#7 |
#9 |
Klewis,
Referring to the second schematic in post #1 (ie the Allison circuit), if you add a resistor (of about 100 ohms) between the emitters of Q11 and Q18, then these output transistors will never turn off and the only switching in the circuit will be the two Schottky diodes. I doubt that you'll be able to measure any difference though. Some other things you might like to try: - Use irf610 and irf9610 Mosfets for the drivers (in place of Q3, Q6), or - swap the output transistors (Q11 and Q18) for some big mosfets (irf240 and irf9240 or similar). Don't forget the gate stopper resistors. Paul Bysouth |
#10 | |
Nice to hear from you again. Your help in the past has been great! I think you meant Q17 & Q18, I'll give this a try. The resistors that feed the emitters of these transistor are different values. I found that if you tune these so that the collector currents are equal, it drives the distortion down further. My implementation plan includes a pot at one of these resistors to balance the current, ultimately replaced by a fixed resistor. I've actually been using mje15034/35's for the drivers, they are much more stable than the 2sc4793/a1837 used in the simulation. They also have a close match pnp to npn (keantoken's suggestion). What do you see as the are the benefits of the mosfets for drivers and outputs? Ken |
| Ultra low noise amp with JFET's - How to reduce the THD ?? | toogool | Solid State | 9 | 21st May 2010 09:54 AM |
| Published/DIY ultra-low THD designs? | leadbelly | Tubes / Valves | 10 | 2nd April 2007 03:41 AM |
| Look at this 42V/20A max PSU, and at this low THD oscillator. | rephil | Everything Else | 3 | 6th August 2006 08:04 PM |
| low THD guitar preamp | Antonix | Tubes / Valves | 4 | 29th June 2006 04:49 PM |
| Page generated in 0.15908 seconds (62.15% PHP - 37.85% MySQL) with 11 queries |
