Old 13th February 2011, 02:09 AM   #1
Default Counterpoint Solid One Power Amplifier
A few questions to throw out.
I purchased a Counterpoint Solid One power amp for very cheap. It had been messed with by someone in the past. Simple things to fix, basically putting the casework back together correctly and straighten out the wire routing. But there are a couple of things that seem out of place.
There is a ceramic disc capacitor in line to the central ground from the input ground on only one channel. Would there be a reason for this?
After reassembly and hookup, I noticed that the transformer buzzes a little. What would cause this? The amp sounds fine, no problems.
I've read some here about Michael Elliott's tube amps but there is not much available about his solid state work. Through email he very nicely provided me with fuse values and which switch to use from Digi-Key, they had also been replaced with the wrong values.
This is a nicely built amp. Makes me wonder why there isn't more information about them.
Solid Solid State Power Amplifier PMA Solid State 265 30th August 2011 08:04 PM
Power Supply Design for a solid state amplifier elaar Power Supplies 61 9th July 2006 08:18 PM
Problem With Hight Power Solid State Amplifier vytas Solid State 8 3rd September 2004 02:49 PM
Problem With Hight Power Solid State Amplifier vytas Solid State 0 2nd September 2004 02:54 PM
Counterpoint Solid 1e SvErD Solid State 10 27th January 2004 07:14 PM
Page generated in 0.14420 seconds (32.19% PHP - 67.81% MySQL) with 10 queries
