Old 12th February 2011, 05:50 PM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default HAFLER OUTPUT STAGE
this is good for hybrid application
visit my best audio idea http://www.esafono.it/DACTONE.htm
Old 12th February 2011, 11:21 PM   #2
djk is offline djk
djk's Avatar
Only if there is a feedback loop.
Candidates for the Darwin Award should not read this author.
Old 13th February 2011, 05:12 AM   #3
Stee's Avatar
Default NFB
like this?
Old 13th February 2011, 05:40 PM   #4
djk is offline djk
djk's Avatar
Sort of.
Your method would give a very low input impedance and has room for improvement.
Some thoughts, in no particular order:
You probably don't need the diodes in the bias circuit. especially with lateral FETs and high bias.
You don't need a high voltage front-end, full output will only require about ±5V drive (the grounded output stage has voltage gain).
You probably only need a one-stage voltage gain from the tube section, the outputs have gain. This would allow a non-inverting feedback scheme to the cathode of the input tube.
You should probably have protection diodes on the gates, a 10V zener and a 1N4148.
You should probably have protection diodes on the gates, a 10V zener and a 1N4148 for each output.
You might consider a single tube section with an inter-stage transformer, or a single tube section with a cathode follower and a current source.
You only need about 8mA per output pair for good square-wave performance, less if you just need good sine-wave performance to 80Khz or so.
Old 13th February 2011, 06:30 PM   #5
djk is offline djk
djk's Avatar
This forum won't save my edits.
You should probably have protection diode on the gates, a 10V zener and a 1N4148.
Don't forget the gate resistor, probably 470R.
One of the current source resistors for the gates needs to be adjustable to null DC off-set.
The grounded output stage works best with a EI type transformer with side-by-side windings. A toroid should have a screen between the primary and the secondary.
A note on the secondaries. If you don't have a screen between the windings, expect a little crosstalk, or go dual mono supplies. A common supply for the front-end is fine.
If you choose to use a non-center tapped secondary, use a voltage divider to establish a DC ground point (see a QSC schematic).
Old 13th February 2011, 10:41 PM   #6
juma is offline juma  Serbia
juma's Avatar
Originally Posted by djk View Post
...especially with lateral FETs and high bias...
2sk1530/2sj201 are not laterals. They have positive tempco and some kind of temperature compensation is needed.
Old 14th February 2011, 02:16 PM   #7
Stee's Avatar
Default thanks a lot for analysis djk
the question is
it's possible have negative feedback from bias resistor?
the partition from 17 V power supply is auround 1/10
Old 14th February 2011, 03:23 PM   #8
Stee's Avatar
Default self or local feedback
like this
Old 14th February 2011, 06:34 PM   #9
djk is offline djk
djk's Avatar
On an inverting summing node the impedance is effectively 0 ohms, so you have an input impedance of 360ohms.
Can your tube stage drive 360 ohms?
(there is another issue with your last schematic but it takes too long to explain and since it won't work right anyway I am not going to discuss this other issue)
juma is correct, if they are not true lateral FETs you will need bias compensation. Although if you bias into class A this may not be an issue (see various N. Pass designs).
Old 16th February 2011, 01:21 PM   #10
Stee's Avatar
Default THANKS
important is ratio
probably need 33K ON 3K3
SAME FOR JFET I THINK
K170 AND J74
Help with input stage driver for EL84 output stage AudioGeek Tubes / Valves 2 20th March 2010 01:38 AM
Could someone explain this Hafler/Strickland output topology to me? SQLGuy Solid State 86 1st February 2009 05:38 PM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
Hafler output FET's testlab Parts 0 21st December 2005 05:12 PM
Hafler amp parallel output transistors Thomas001 Solid State 1 19th February 2005 04:21 PM
Page generated in 0.12191 seconds (73.39% PHP - 26.61% MySQL) with 11 queries
