WHAT IS THE ADJUSTMENT OF V1 AND V2?
#2 |
finaly i got this,
Final Set up And Adjustment No attempt should be made to set up or test a power amplifier module that is not correctly mounted on a heatsink. Make sure the main power supply is fused and the work area is clear. First check all your work and make sure the output devices are insulated from heatsink. The set up is done without an input or a load connected to the power amplifier. 1. Check the power supply is operating correctly and verify the rail voltages. Switch the power supply off and check with a multimeter that the rail capacitors have discharged. 2. Correctly connect the ground, positive and negative leads to the power amp module. 3. Remove the PCB fuses and replace with 100 ohm 5 watt resistors. Connect a multimeter that is set to the 20 volt scale across the positive rail 100 ohm resistor. 4. Check that the power supply connections are correct one last time and switch on. If the multimeter reading goes off-scale, turn off immediately and find the problem. Check also the 100 ohm 5 watt resistors; they may have gone open cct. 5. If everything seems ok adjust VR2 to set the output stage bias current, by measuring the voltage across the positive rail resistor. Adjust for a reading of 3 volts per output FET pair. I.e. For a 6 FET board set for a voltage of 9 volts. This equates to a bias current of 30mA per FET pair or 90 mA total. For a 10 FET board set for a voltage of 15 volts. 6. If everything seems ok, check the output offset voltage and adjust VR1 to achieve an offset of less than 10 mV. 7. All being well switch off, back off the bias control trimmer (VR2) and replace the 100 ohm resistors with 10 ohm 1 watt resistors. Switch on again and re-adjust VR2 to get 0.3 volts per per FET pair across the positive rail 10 ohm resistor. 8. Switch off, remove the resistors and put the fuses back in. Switch on, re-check the offset voltage and adjust with VR1 if necessary. The amp module is ready, connect the input and output and enjoy. |
#3 |
do not try this amp useless .
the transistors get very hot so u need big heatsink. preset adjustments are very difficult. don't try,don't try,don't try. |
#4 |
Then you have built it incorrectly or your MOSFETs are fake - many here have built the NMOS200 design and had it work perfectly
#5 |
Absolutely right jaycee, i also have build this amp NMOS every version of it, and i dont have problem with thermal, doesn't have big issue with it, maybe your mosfet are fake or bias too high, always check bias voltage before put final output power transistor
#6 |
Hi nazirdigi,
Do not irritate Quasi's fans, there are quite a large number of them. There is a saying "when you point your finger at others, there are 3 pointing at yourself". Try to make sure what is wrong with your own work rather than saying someone else work is no good. Make good use of resources from this forum. Ask instead of accuse. I think many will be more than willing to help. But with this kind of attitude, you will go nowhere. There are hundreds of way to blow a project but there are only a few ways to success. Check you own work over and over again before making comments like this. There may be a thousand success but you may not the the next one. Sorry if you find this rude but just try to straighten out some attitudes. BP |
#7 | |
after input signal and working condition output transistors getting very hot. |
#8 |
What size heatsink are you using? A Photo would probably answer this question best.
#9 | |
what is the maximum voltage for nmos200 247? |
#10 |
http://sites.google.com/site/quasisd...ries/nmos200-1 is the new website. 50V rails max.
| pcb of nmos200 - to247 | katiyar | Group Buys | 1 | 31st March 2011 06:14 PM |
| Finished Nmos200 | dipsi111 | Solid State | 14 | 14th December 2010 09:44 PM |
| CAN I USE THIS POWER SUPPLY FOR NMOS200 247 WHICH PSU NEED TO USE? | nazirdigi | Solid State | 0 | 14th December 2010 01:10 PM |
| Nmos200 Amp | Giorgos3924 | Solid State | 1 | 29th June 2010 10:49 PM |
| Page generated in 0.14294 seconds (62.39% PHP - 37.61% MySQL) with 11 queries |
