Proud Union Member
Hello all,
I have been tasked with designing an impedance/FFT sweep rig using an AP System 2 at work. We have literally hundreds of very good amplifiers but they are all rental items and subject to, well, rental. So the idea is to build an amplifier for in-house measurement use. I have built several amps for listening and MI, but what I'm looking for an amp that will measure and perform really well. The amp can be any class, but must fulfill the following: FR from near DC to at least 20kHz, probably needs to be DC coupled. Power output of around 10-20W into 8ohms. Extremely low THD at specified output power. Must fit into a 2 space rack chassis. Candidates include: Mini-A LM1875 LM3886 DX Amps 41Hz Amp3,6 (Not sure if they can be DC Coupled) I'm open to suggestions. Thanks! |
#2 |
The F5 with Cviller's boards will do a very nice job -- the '1875 and '3886 are great chips but I don't think they'll meet your THD criteria. LM4702 (LME49830 etc.) do a really good job.
#3 |
I can never remember the name of the project, but someone here has made a circuit using these chips, enclosed in the (control) loop of a high performance op amp, which reportedly takes it a step higher, performance-wise. Should fit your requirements.
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#4 |
Might I suggest Doug Selfs Class B "Blameless" design which is quite happy run on lower supply rails.
Power output: 50 W rms into 8 ohm Distortion: Below 0.0006% at 1 kHz and 50W/8 ohm Below 0.006% at 10 kHz Slew-rate: Approx. 35 V/μsec Noise: 91 dBu at the output EIN: 117 dBu (referred to input) Freq Response: +0, –0.5 dB over 20 Hz–20 kHz By using Dougs two pole compensation the 10khz THD can be pushed to 0.0015%
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#5 |
I have built some Blameless amps. Subjectively, noise is very low at the lower frequencies; was the best I had used in my loudspeaker measurement setup. IMO, mediocre amplifiers fall short mostly in terms of noise levels in the lower frequency range.
#6 |
the real question is what are you willing to give up in size, power, distortion performance, output protection, reliability, useability, cost, design/build time, certification...
if you can compete in most of the categories your company should be building, selling, renting out the amps you make because the companies that are building the amps you rent have experience and in a competitive market can't charge monopoly profits - so their prices are a fair reflection of value if you can make enough trade-offs: "diy" time is "free", buy the most recent, highest level of development integrated Si for the application, large, "ugly", low efficiency are a few categories you can make some gains re established products if still wanting to build rather than buy then forget about "optimum Class B", or "low/no feedback" audiophoolish nonsense wrap today's best op amps around a Class A or really heavy bias AB output stage with 60 dB or more 20KHz loop gain at lower current demands "grounded bridge" with floating supplies boost Vout so you can use CFA chip amps - paralleled LT1210 1 A output in TO-220 CFA op amp would be one output candidate next on my short list would be discrete CFP output stages with 2-4x V gain and composite op amp input/driver project difficulty is critically dependent on what you mean by "8 Ohm load" do you mean: a 8 Ohm resistive load a range of "8 Ohm" individual dynamic drivers with complex impedance from mass-spring resonance impedance peak and 4-6 Ohm series R any "8 Ohm" multidriver loudspeaker where passive crossovers can give large complex impedance swings and drop to <<1/2 of "8 Ohms" at some frequencies if a complex load do you have to drive the "worst case" signal that peaks the current draw by 2-5x for a given nominal load impedance while +/-20 V, 2.25 A will give you ~ 20 Wrms into 8 Ohms resistive load you could need 5-10x current capability depending on assumptions about the load and signal if you can just turn down the V to keep the current in range then maybe ~60-70 W continuous dissipation Class A could work (to simplify design reserve V,I "headroom" to keep output stage devices away from saturation, starvation caused nonlinear operating regions) but in 2U that may need a fan, certainly if sizing for higher current peaks forced air cooling, switching power supply will be required in such a small space Last edited by jcx; 12th February 2011 at 03:14 PM. |
#7 |
Proud Union Member
Thanks for the suggestions so far. I have started making comparisons between some of the amps mentioned.
jcx, many really good points made. I'll try to address as many as I can. First, as this will only be for in-house use, no certification is necessary for this beyond normal common sense building practices. I'm looking for: Very good performance. I should clarify here. We need about 20W at 8ohms and the ability to drive 4ohms. Dips in impedance below 4ohms will certainly be a consideration. (In the case of the F5, I had already planned on populating all output devices) Ability to handle the possibility of a faulty driver at full power Decent reliability- 10 year life span would be nice Size needs to be 2RU if possible, although I might be able to do 3RU Cooling can absolutely be forced air. It's not going to live in a living room. Cost isn't the larger issue I don't think. We will already have many of the build supplies- PSU, Chassis, Heatsinks, Etc (We have stacks of dead console PSU's) Usability will be for measurement purposes and probably subjective listening in a repair lab environment. Build time- I probably have about 50Hours to build it. I think being able to buy PCB's will be a factor. As far as renting out amps we make- Even though we rent many pieces we build, I don't think amplifiers will be one of them. There's no way we could build an amp such as a LabGruppen for less than just buying a pallet or two at a time. Even the smallest amps we use, D-45's- there's no way we could build one for what we pay for them. Thanks! |
#8 |
I still think Dougs designs fit your requirements. PCB's available.
The Signal Transfer Company: Load-Invariant Power Amplifier http://www.signaltransfer.freeuk.com/index.htm
#9 | |
Samuel |
#10 |
With those load requirements, have you thought about a KrellKlone? With forced cooling it would easily fit in a 2 or 3u case. Something like the one of the old TAC PSUs with the big heat tunnels down the centre would be perfect.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
| How to do measurement on Class-D amplifier | fumac | Class D | 21 | 26th March 2008 12:36 AM |
| Choosing a amplifier - What's in a name? | Flyin11 | Car Audio | 11 | 28th October 2007 07:35 AM |
| Help choosing measurement and modelling setup | SimontY | Multi-Way | 65 | 26th April 2007 05:05 PM |
| Choosing amplifier for PC speakers | soundNERD | Chip Amps | 9 | 27th September 2003 01:10 AM |
| How do you make up your mind while choosing a quality power amplifier? | PSS AUDIO | Solid State | 26 | 31st August 2002 09:48 AM |
| Page generated in 0.16010 seconds (73.46% PHP - 26.54% MySQL) with 11 queries |
