Old 11th February 2011, 01:05 PM   #1
Default Citronic PPX1200 question
Hi, can anyone tell me the bias setting for this amp??
Old 11th February 2011, 03:48 PM   #2
burbeck is offline burbeck  United Kingdom
100mA per mosfet pair
regards
bob
Old 11th February 2011, 04:34 PM   #3
Thanks Bob, I am seeing 5 pair per channel, so 500mA sounds good.
Old 11th February 2011, 05:12 PM   #4
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
100mA per pair is generally accepted as a good value for optimum sound quality, but in this case you are looking at 160V rail to rail so with 2 channels you will be dissipating 160W idling.
That is quite high for a PA amp. I'm not sure about the recomended bias for the Citronic but my c-audio mosfet amp has a quoted bias of 150mA This is probably quite enough to avoid any crossover distortion
Old 11th February 2011, 07:15 PM   #5
The schematic shows a total of 200v rail to rail (+100v to -100V), I've read elsewhere that these old citronic amps do run hot at idle, the cooloing fan will even cut in and out. Just got hold of this one and wanted to check that all was well before using it in anger!
citronic ppx help and rotel question lt cdr data Solid State 1 12th September 2010 08:14 PM
Schematics for a Citronic PPX1200 BruceBenson Solid State 20 12th March 2009 03:32 PM
CITRONIC PPX for help pengpeng Solid State 1 10th February 2009 01:34 AM
Citronic Cd4 Info big jim Parts 0 27th June 2008 10:19 AM
Citronic amp mickb Solid State 3 27th February 2008 09:14 PM
Page generated in 0.06798 seconds (77.17% PHP - 22.83% MySQL) with 10 queries
