I need suggestions for used high power SS mono blocks.
I'm thinking 250 per side minimum. Thinking on ESL build. Champagne tastes-beer budget. Thoughts run to Carver, Adcom, some Parasounds. Saw what looked like some serious older Denons the other day. Any suggestions under $350 per side appreciated. I would consider Class D Amps if someone can point me to an easy build. I plan on buying an existing Pre. Yes- I know some ESL's supposedly don't need high wattage. Not willing to take the chance and too much can't hurt the equation. TIA |
#2 |
Nobody?
#3 |
Hi ...I was making confusion between watts and dollars ,and between DYIing and buying finished products . I just can mix them and say : Class D ,which can be made using pre-assembled amp units ,might be efficient (dollars/watt/quality)for sub-woofer ,even if some say it has the maturity to play fullrange without 'tricks' . Of course you'll need to mount by yourself a PSU for it ,which will cost you around 250$ or 350 $
![]() In the end ,whatever choice you may take ,you'll end in hearing (when playing music ...) a well done PSU delivering much current |
#4 |
Thanks Pico.
I'm thinking 'no replies' a result of the ridiculously low amount I stated as budget. There are used amps out there at prices I mentioned. I've unfortunately been burned on Ebay 6 times already. Buying used at AudioGon has worked out but prices then go higher. Class D has been going through my mind and other Forums I frequent give them high marks on SQ even using several channels but I'm to a degree doubtful. Hate to spend money being unsure. |
| Yes I have searched | drtool | Introductions | 2 | 28th March 2009 05:38 PM |
| Holy Luck Batman,,, | planet10 | The Lounge | 0 | 22nd January 2009 06:10 AM |
| Bad Luck! | sobazz | The Lounge | 0 | 5th March 2004 08:33 PM |
| Am I just having bad tweeter luck? | random_id | Multi-Way | 1 | 21st February 2004 09:46 AM |
| Page generated in 0.07820 seconds (64.38% PHP - 35.62% MySQL) with 10 queries |
