Hey there,
im designing a VCA compressor for a university project, I've got most of my stages done am now refining my control voltage signal path. The questions i have are; 1. The signal has been rectified and then low passed. What is an appropriate frequency to low pass my audio to create an acceptable control voltage signal? I've seen on a related post that 20Hz was used, this seems too aggressive to me and would ruin the dynamics of the control voltage, or am i way off? I cant find any information on this anywhere else, it seems to be one of those questions no-one thinks to answer maybe? 2. I have been running some simulations using a low pass sallen and key filters with a bessel design, but i the low frequency cut off is giving me a really long rise time (~50ms), i need this right down as its ruining the point of trying to develop a fast response filter. Any suggestions of topolgies or anything that i could use to get a rise time of say 1ms? any advice would be appreciated. Nick (I know that I should really have an RMS control signal but for the purposes of a learning experience i didnt want to just stick a chip in there and have it do it for me!) |
#2 | |
jD If it doesn't fit force it, if it breaks, buy another one. |
#3 |
Yes you will need fast attack times if you want to catch fast rising waveforms, anything percussive. Your low pass filter limits the attack speed. For 1ms attack you need approx 1khz. Send a square wave into the filter, adjust the cutoff freq and see what comes out (rise time).
#4 |
There is an agc idea here:
www.edn.com/contents/images/080405di.pdf The nice thing about it is that you can make it from junk box components. You don't even need a FET but it is certainly not hi-fi by any measure. |
| Scaling voltage for VCA | dan_thompson87 | Chip Amps | 2 | 13th January 2010 12:08 PM |
| [help] Full Wave rectification for VCA control voltage | dan_thompson87 | Power Supplies | 10 | 27th November 2009 01:47 AM |
| voltage control | kanifee | Parts | 3 | 26th February 2009 10:32 PM |
| Which VCA for Digital volume control | gmphadte | Analogue Source | 8 | 30th September 2004 11:21 AM |
| Page generated in 0.09927 seconds (71.30% PHP - 28.70% MySQL) with 10 queries |
