I feed my phono amp from a signal generator through an inverse RIAA circuit. It looks like the 1KHz is OK but the 10KHz and 20KHz looks very different from the input signal (the blue ones at the lower side). What do these curves mean to sound quality?
PS - The sound of this phono amp has nothing wrong and in fact, it blows away my old ASR Basis. Last edited by Sunsun22; 7th February 2011 at 03:48 AM. |
#2 |
normal. A square wave is made up of a fundamental frequency and higher order odd frequencies that diminish in amplitude as the frequencies go higher. If you go high enough in freq on the input the output will look more and more like a sine wave. Remember the inverse RIAA is not perfect either.
#3 |
a rectangle react very sensitive to changes in amplitude and phase response of the testes circuit. If the rising part of the curve (left) is rounded as it shows in the upper yellow curves with rising test frequency it indicates a lowpass character. If thats the signal You feed into Your RIAA-Preequalier it shows that Your Signal-Generator is rather limited in frequency range. Assuming perfect Prequalizing and a perfect RIAA the output should look the same as the input. Since all practical circuits show a lowpass behaviour because of bandwidth limits one would expect the rising edge of the signal to be more rounded than the input signal. The opposite is the case here, which would show in a rising amplitude response with rising frequency. So either the Prequalizer network or the RIAA seems to show a amplitude response that deviates from the normal. jauu Calvin |
| How do these curves look? | astouffer | Tubes / Valves | 23 | 11th June 2009 09:52 PM |
| Curves for 12AH7 | jane | Tubes / Valves | 0 | 1st May 2009 11:03 AM |
| Derive Triode Curves from Pentode Curves? | dsavitsk | Tubes / Valves | 3 | 14th May 2007 06:10 PM |
| Curves, curves, and more curves | CarlyBoy | Tubes / Valves | 5 | 1st December 2006 10:11 AM |
| where's the curves? | bostonswoop | Multi-Way | 13 | 13th March 2006 12:32 AM |
| Page generated in 0.08421 seconds (72.53% PHP - 27.47% MySQL) with 11 queries |
