NAP140/NCC200 Clone with PSU - diyAudio
Old 5th February 2011, 09:20 PM   #1
Default NAP140/NCC200 Clone with PSU
NAP140/NCC200 clone with onboard PSU.
Clone of NCC200, but without output inductor.
Schematic doesnt contain the correct values yet and not all the caps/transistors are the right ones. But I wanted to get most of the layout done first to get a feel of the size of it.
Size is about 22 x 12 CM.
Old 5th February 2011, 10:41 PM   #2
Banned
I'm not sure I would want to put the bridge rectifiers on the amp pcb
Old 5th February 2011, 11:17 PM   #3
Thought about that as well, they might make too much noise.
Maybe Ill leave them off in a new version. Could fit 1 PSU cap more pr rail
instead of the rectifier.
Old 5th February 2011, 11:30 PM   #4
Greg Erskine's Avatar
Hi Neutrality,
I have been caught using generic transistors before. Be careful of the pin-outs of the first 2 stage transistors as optimum PCB design can depend on the pin order, especially when the transistor is connected to a heat-sink. Sometimes you can just rotate them 180 degrees without a problem.
Did you miss the input cap on purpose?
regards
Greg Erskine
Old 5th February 2011, 11:36 PM   #5
Originally Posted by Greg Erskine View Post
Hi Neutrality,
regards
Generic transistors are just used to get the layout going, I will be going over each of them to check for correct pin out/package and change those who needs to be changed. The same goes for the caps, the ones currently used are just placeholders.
Wrt the input cap, ehm, thats a mistake on my part. I forgot it.
Old 5th February 2011, 11:43 PM   #6
Now that I've looked at it again, the input cap isnt missing I just put it the wrong place, it goes from input to ground, well, thats definately wrong lol. C1 should have been the input cap.
Old 5th February 2011, 11:49 PM   #7
Another thing I have been thinking about is spreading the output transistors for better cooling. Better get the most out of the HS.
EDIT: Could make room for double the output transistors. But dont know if the rest of the circuit is up for it.
Old 6th February 2011, 05:31 PM   #8
Removed onboard rectifiers, added correct caps, and redid the whole board more or less as the real NCC200 board, but with onboard caps and more space between the output transistors. GND plane has been removed as well. Only thing missing is correct version of 3 of the transistors.
And it is now a single sided board, easier and faster for me to make a prototype this way. Before I spend any real money on a professionally made PCB.
Output transistors will be either MJ15003, BUV20 or BUX20 from Semelab(50A, 350W max dissipation)
Old 6th February 2011, 07:32 PM   #9
Banned
I think you have room to make C1 a film cap as an option.
Old 6th February 2011, 07:38 PM   #10
That was something I have been considering. Theres plenty of room for it.
There should be enough room for it to be a drop in replacement.
But if not, I can move most of the bottom circuit more to the left if needed. One of the reasons why I didnt make it as compact as I could, always good to have more space for changing components.
Currently looking at different versions of the basic circuit, including modifications from SKA Audio. But they might change the circuit to something else, but lets see about that.
Avondale NCC200 module pics IanHarvey Solid State 18 26th August 2012 01:17 PM
Regulated PSU for Leach Amp clone. Dougie085 Parts 0 7th July 2010 03:13 PM
Inv Gain Clone with on board PSU anbello Chip Amps 65 7th May 2008 01:32 PM
GB150 (SKA), GB300, NCC200 and chip-amps Dr.H Solid State 2 1st September 2006 06:06 AM
SELLING: NAIM NAP140 + NAC 42.5 + grey snaic clable aquila.77 Swap Meet 0 5th March 2006 05:00 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
