Old 27th May 2012, 01:22 AM   #101
Default TT-Triple
Another update:
1) I managed to solve why the PS Regulator speaker protection was randomly turning on, although the problem is not caused by the amplifier itself. Now that summer is approaching I have the air conditioning enabled. Occasionally when the HVAC condenser fan turns on outside, it introduces some combination of voltage and EMI transients into my electrical network. I verified this behavior by turning on and off breakers on the HVAC circuit in my home. Every time the speaker protection would immediately enable after I switched the circuit breaker from off to on (amp located on a separate circuit).
I installed a surge protection power strip with built in EMI/RFI filtering into my system as a solution (see attached photo). So far so good; this seems to have solved the problem. No cutouts, and the central air conditioning has been on for the last few days.
2) I measured the amplifier heatsink cutout temperature, and I've never seen it rise above 55C, even after listening for several hours at extended volume (see attached photo).
3) As mentioned in a previous post, ground loop noise is effectively eliminated.
4) The speaker protection employed in the PS Regulator is very unique. It does not employ relay contacts in the signal path, which introduce noise into the signal. Dado managed to modify an old John Linsley Hood (JLH) design from the 1980's. As explained above, it works all too well. I'm confidant that my expensive speakers will be protected by this circuit.
5) I can't stress enough how phenomenal this amplifier sounds.
/Mason
Old 27th May 2012, 09:28 AM   #102
Add EMI/RFI filtering to the aircon. Source attenuation is always better than at receiver
Old 9th June 2012, 04:47 PM   #103
keantoken's Avatar
Dadod, have you measured the bias stability in real life? Does it overcorrect or undercorrect? Also, the rectified current through the negative driver base will cause bias to drift down with power, and this is independent of temperature effects. This is one reason to use a CFP Vbe multiplier.
Old 9th June 2012, 05:07 PM   #104
dadod is online now dadod  Croatia
dadod's Avatar
If you read trough the thread you can notice that I changed resistor in one cannal to have the bias stable. In real life I try to hove a bit overcompensated, just a bit. It looks that one transistor Vbe multiplier is sensitive to Hfe. I followed yours posts, very interesing, But to use a CFB Vbe multiplier was to late for me as I hade the PCBs made for all six channels I am going to make. I am quite satisfied with the thermal stability and after prolong listening it was not changed more then 10%.
dado
Old 9th June 2012, 05:28 PM   #105
keantoken's Avatar
It's a nice amp Dadod. It seems a bit daft to say this after it's all been built, but:
At high powers, 3rd harmonics can be reduced by adding two resistors, from emitters of outputs to bases of drivers. These resistors compensate for high-current Hfe droop because the logarithmic Vbe imposed across them causes them to draw less current at high output currents. Depending on the input stage and VAS linearity this may increase 2nd harmonic distortion below these levels. If the input stage and VAS are not very linear the 2nd harmonics at low power levels will rise however. I wonder if this modification improves dynamics. I am not really sure if it works this way in a triple EF however, because it seems in this case most of the distortion comes from the output switching distortion voltage imposed across the VAS and Miller compensation.
Usually this modification eliminates the need for a CCS because the same function can be provided by a special bootstrap, and it makes the CCS useless anyway. The effect is to decrease output stage current gain, in return for linearity. That is to say, open-loop linearity increases unless the input and VAS stages are not very linear.
What would you suggest for a computer as a source? It generates so much of it's own noise.
Old 10th June 2012, 01:54 AM   #106
Default Thermal stability improvements?
Hi Dado
Very nice amp It seems excellent performance at reasonable complexity. You have made a smart balance of improvements by TMC and ThermalTrak without too many problems from unproven techniques.
I have one question. It seems a triple with CFP + EF would be as low distortion and a little easier to thermally stabilize. Did you consider this and reject it? Or just decide to stay with conventional, proven output circuit?
The CFP+EF circuit looks attractive and I am a little surprised it is not more common so that is why I ask. I explain my idea a bit more in Bonsai's E-amp thread if you are interested but I would like to have your opinion too.
Best wishes
David
Old 10th June 2012, 10:29 AM   #107
dadod's Avatar
Originally Posted by Dave Zan View Post
Hi Dado
Best wishes
David
Hi David,
I decided to stay with proven output circuit, I would not say conventional.
Today I simulated CFP + EF as in Roender amp and I couldn't get it stable without adding some capacitors, first between the drivers base-collector and it was just possible to simulate with 220pF, but with worst PM and GM then the triple EF.
I then put 100pF between predrivers base-collector and stability was better but distortion was close to ordinary triple. I am not sure how Roender get stable his OPS with no capacitors.
difference between ordinari Triple and CFP-EF:
EF Triple:
Fourier components of V(vout)
DC component:0.00212666
Harmonic Frequency Fourier Normalized Phase Normalized
Number [Hz] Component Component [degree] Phase [deg]
1 2.000e+04 3.084e+01 1.000e+00 -2.66° 0.00°
2 4.000e+04 2.768e-05 8.977e-07 94.19° 96.85°
3 6.000e+04 3.022e-05 9.801e-07 150.01° 152.68°
4 8.000e+04 1.558e-05 5.053e-07 -136.70° -134.03°
5 1.000e+05 4.853e-05 1.574e-06 -12.31° -9.65°
6 1.200e+05 8.743e-06 2.835e-07 -160.98° -158.32°
7 1.400e+05 1.272e-05 4.126e-07 29.92° 32.58°
8 1.600e+05 1.473e-05 4.778e-07 -139.96° -137.29°
9 1.800e+05 7.758e-06 2.516e-07 31.20° 33.86°
Total Harmonic Distortion: 0.000225%
CFP-EF:
DC component:0.00222449
2 4.000e+04 3.370e-05 1.093e-06 85.92° 88.58°
3 6.000e+04 2.753e-05 8.929e-07 150.93° 153.59°
4 8.000e+04 1.492e-05 4.837e-07 -135.18° -132.51°
5 1.000e+05 3.163e-05 1.026e-06 -14.48° -11.81°
6 1.200e+05 4.765e-06 1.545e-07 170.83° 173.49°
7 1.400e+05 7.618e-06 2.470e-07 119.75° 122.41°
8 1.600e+05 9.969e-06 3.233e-07 -142.38° -139.71°
9 1.800e+05 9.777e-06 3.171e-07 154.56° 157.22°
Total Harmonic Distortion: 0.000189%
Do you have proposal how to tame CFP-EF as it has potential?
dado
Old 10th June 2012, 10:38 AM   #108
That 225 to 189 is a 1.5dB reduction in predicted distortion.
Old 10th June 2012, 10:50 AM   #109
dadod's Avatar
I am not sure what resistor value to use, and I simulated with 220ohm.
I don't see any 3rd harmonic reduction, look at FFTs. This simulation is at max power.
Could you suggest the resistors value?
dado
Old 10th June 2012, 11:14 AM   #110
Today I simulated CFP + EF as in Roender amp and I couldn't get it stable without adding some capacitors..
dado
No proposal yet! I have a few ideas but need to think more.
I believe a few people did have some trouble with Roender's amp when they built copies. I will check their solutions.
I am interested in better thermal stability but lower distortion is a nice bonus. Even if, as Andrew notes, it's only 1.5 dB.
But your decision to stay with a proven output circuit while you tested TMC and ThermalTrak is very reasonable and seems to have worked well.
Best wishes
David
Is Dado an informal form of Damir?
Compact Sized LME49810/11 +ThermalTrak Amp panson_hk Chip Amps 301 1st January 2013 05:22 PM
MEMDIST POWER AMP + JC + TMC - help to set up padamiecki Solid State 7 7th December 2011 12:34 PM
New 200 watt Kit amp features ultra low distortion and Thermaltrak devices snoopy Solid State 56 3rd May 2010 08:42 AM
Mini-Sized 49811 ThermalTrak Amp panson_hk Chip Amps 3 1st April 2010 08:06 AM
What to do with TMC tube radio gear? diamondsouled Tubes / Valves 4 31st March 2009 01:30 PM
Copyright ©1999-2013 diyAudio
