Will the damping factor of an amplifier is not made again by the resistors in the crossover to naught?
#2 |
The speaker designer/manufacturer will, or should, design the crossover and how it integrates with the drivers using normal amplifiers for the market that he has targeted for his speaker.
They may even try to make their speaker work well with all reasonable quality amplifiers or even target their speaker performance to sound good with really poor performing amplifiers. The designer makes that choice and it takes account of how the target customers will hook up their speakers.
regards Andrew T. |
#3 |
yes you are right - Use active crossovers!
Once you hear the improvement you will never allow passive crossover components in series with your speakerunits again.
STOP - Hammertime! |
#4 |
What he ^^ said!
#5 |
First the speakercable set down the damping factor, connectors do not make it better, and even if you use lowest loss x-over components, the factor will be reduced usually down to 10 in the real world, may be 20 in best case.
#6 |
No one has an argument for passive speakers in the high-end segment. That reassures me to hear
The next Amp I will construct is a high quality modul for aktive load. |
#7 |
The DCR of the woofer inductor is the biggest problem.
The total series resistance should give a minimum damping factor of 20, or it has to be factored into the box design. Remember, box size is roughly proportional to the square of the Qts, and that series resistance raises this. Going from a Qts of 0.3 to 0.4 can almost double the required box size.
Candidates for the Darwin Award should not read this author. Last edited by djk; 4th February 2011 at 06:57 PM. |
#8 |
I prefer active systems as well, but IMHO, damping factor is often overrated.
Extremely high damping factors are usually the result of very high amounts of global negative feedback. There are well regarded amplifiers like this as well as those with modest damping factors. Some amps are designed with intentionally low damping factors and work remarkably well with some full range drivers. So, yes build more amps so you can make active systems. If high damping factor floats your boat, then by all means choose designs with that characteristic. But don't be afraid to try an amp with a lower damping factor. You may like it. |
#9 |
I am not narrow-minded, and yes, I have heard a Tube-Amp on passiv speakers and it sounds fantastic.
Even with crossover. |
| Headphones and damping factor? | Christer | Solid State | 17 | 10th November 2005 04:56 PM |
| Aleph4 damping factor | alanyeoh | Pass Labs | 1 | 17th August 2004 09:11 PM |
| Damping factor | Cro maniac | Chip Amps | 29 | 8th May 2004 01:16 PM |
| Damping factor | thylantyr | Solid State | 9 | 14th March 2003 06:37 AM |
| Damping factor..????? | emarald | Solid State | 15 | 30th January 2003 02:41 PM |
| Page generated in 0.11021 seconds (70.85% PHP - 29.15% MySQL) with 10 queries |
