Basically with my planned build I will have 170mm wide 60mm high and 250mm long absoultly max sizes. I would like a 1000VA traffo and I have found some but they are too small does anyone know of anywhere to get low profile high power traffos?
Thanks Boscoe
I thought about it once, but then thought again. |
#2 |
Junk shop, inside an used amp or broken amp, just ask a junk shop seller of what you need, and may they will ready with your request for a week. I usually do that for special items. Explain carefully about what you need, because most of them are not an expert.
#3 | |
![]() OS
Mongrel website , always current and updated : http://67.248.209.21/D%3A/WEBSITE/ |
#4 | |
Thanks for the advice though!
#5 |
Hi Boscoe
Try airlink transformer's. They will build whatever you want as long as it is viable. Mad Mark |
#6 | |
PS - Dr. Bora's "sigma" is a much better goldmund clone (below) cascode it to use the FET's and you would have a better , more stable , proven design. OS
Mongrel website , always current and updated : http://67.248.209.21/D%3A/WEBSITE/ Last edited by ostripper; 4th February 2011 at 12:13 PM. |
#7 | |
#8 |
Hi
A local Oz manufacturer produces 1KVA toroidals only 65H x 165D. These are based on Antrim Transformers (N.I.) technology and mey be available from agencies throughout the UK. Have you checked them out? In any case, what problem might you forsee in a single 800VA trafo? Unless you are planning on really irritating the neighbours or sustained load testing for fun, it seems a bit of overkill for domestic use.
regards Last edited by Ian Finch; 5th February 2011 at 01:28 AM. |
#9 | |
#10 |
Because you read things on the INTERNET, it is not necessarily true. Unfortunately many people consider the INTERNET their text book/bible and learn a load of rubbish.
Why would you want to use a bigger power supply than is necessary, you think that you will get something magic from it?
| voltage multiplier based on SS trafo - LONG | ErikdeBest | Tubes / Valves | 33 | 10th September 2010 08:04 AM |
| Any suggestions on setting up a dedicated electronics work area at home ? | Ohighway | Equipment & Tools | 24 | 16th September 2008 11:41 PM |
| 18V or 36VCT Small Trafo wanted | Zero Cool | Swap Meet | 3 | 7th April 2005 10:48 PM |
| Suggestions wanted- 10" Subwoofers for very small bandpass enclosures. | treedog | Car Audio | 6 | 16th January 2005 05:17 AM |
| PSU made with power op-amp and small trafo | carlosfm | Chip Amps | 2 | 9th July 2003 04:01 PM |
| Page generated in 0.22066 seconds (48.21% PHP - 51.79% MySQL) with 11 queries |
