Old 2nd February 2011, 01:41 AM   #1
96lt4c4 is offline 96lt4c4  United States
Default Old crate G40C buzzing after warm
I have had this amp for 10 years and it has always done this. After about 5 to 10 minutes of the amp being turned on it starts to buzz, humm and it
oscillates. I found the schem. for it on this site and have it tore down. I Found one cap that looks like it had came apart and someone wrapped black tape around it. It was a 1 mF 5 volt. I replaced it with a 1 mF 10 volt and still have the problem. I am going to check the voltage coming out the secondary side of the transformer next. Just wondering if anyone has any ideas. I have no idea how old this thing is.
Old 2nd February 2011, 02:57 AM   #2
llwhtt is offline llwhtt  United States
Almost all Crate amps of that vintage use zener regulation for the op amps. The 5 Watt dropping resistors and the zeners themselves run very hot and the solder joints go bad. Also check the solder joints on the main filter caps, they tend to break. Another problem you'll see when you take it apart is that all of the nuts behind the knobs will be loose, certainly not tight, anyway check all of the solder joints on the controls and anything on the PCB that goes to the outside the chassis, jacks, controls, switches, etc. In my experience that should take care of 90% of Crate problems that are sorta still working, ex-warranty shop. Get a magnifying glass to inspect the solder joints, look for "rings" around the leads, those are cracks.
Craig
Old 2nd February 2011, 08:03 AM   #3
Enzo is offline Enzo  United States
And don't bother the transformer, the likelihood of it being wrong is very tiny.
As Craig points out, check the +15v and -15v power supplies.
Old 2nd February 2011, 01:10 PM   #4
I knew the likelihood of the transformer being bad was slim. Thanks guys i will check all the solder joints.
Old 2nd February 2011, 07:44 PM   #5
I found a bad diode, it looked like it had been getting pretty hot and I wasn’t getting any voltage across it so i pulled it out. It was shorted. It is on the power supply side next to a very large 120 ohm ceramic resistor. The diode was pretty good size as well. All I had were some bridge rectifiers so I used one side of the rectifier to replace it and cut the other 2 legs off. Now I am getting 15 vdc on one side of the diode. I have some pictures that I can post later. I also pulled the 4 diodes off that made the bridge and replaced them with an integrated bridge rectifier.
Old 2nd February 2011, 09:11 PM   #6
New bridge
New diode
Old 2nd February 2011, 09:21 PM   #7
The 120 Ohm 10 Watt resistor (R115) is the dropping resistor for the + supply, D17 (1N5357A) is the zener. Did you replace it with a rectifier diode?
Craig
Old 2nd February 2011, 09:51 PM   #8
Craig
Yes using one diode in the rectifier, 2 legs cut off. I didnt have one as big or the same as the one that came out. Will this not work?
Old 2nd February 2011, 09:55 PM   #9
Its been a long time since I was in tech school. I just looked up a Zener, and it looks like thats what needs to go back in there.
Old 2nd February 2011, 10:04 PM   #10
It needs to be a zener, the rectifier you have there now is not doing anything. The voltage will be too high, do not run the amp until the zener is replaced. D17 is a 1N5357A and D18 is a 1N4744A.
Craig
Crate guitar amp buzzing MexicanGringo Solid State 1 13th March 2010 03:05 PM
Troubleshooting Crate G40C amp mandomaniac Instruments and Amps 12 13th April 2009 08:32 AM
crate amp help mahlin Solid State 0 7th May 2006 01:24 AM
Crate reverb cqboling Instruments and Amps 1 10th April 2006 10:36 AM
My amp gets warm... Jye Multi-Way 6 21st November 2003 11:53 PM
Page generated in 0.11510 seconds (73.71% PHP - 26.29% MySQL) with 10 queries
