I tried the ebay MX50 DIY Kit, Class AB 100W+100W; Worked but problem.
Old 23rd January 2013, 04:13 PM   #51
audio_tony is offline audio_tony  United Kingdom
Send a message via MSN to audio_tony
Default MX50 100W + 100W
I built the same amp - however the modules I bought off Ebay were pre built and tested.
I'm not sure if the circuit diagram I posted is correct for the modules I have - but it was the one published on the auction page.
Details here is anyone is interested.
Mine is running at a lower power, as I'm using a 35-0-35 Vdc supply.
Old 25th January 2013, 03:05 PM   #52
sbrads is offline sbrads  United Kingdom
Any verdict on sound quality yet?
Old 25th January 2013, 05:13 PM   #53
It sounds absolutely superb.
I currently have access to several power amps, Harman Kardon HK870, NAD2200 (very modified),Rotel 850 - and it beats them all, hands down.
It's very detailed, and the bass is simply superb too.
Source is Marantz CD17 (modified), Cambridge Azure DAC Magic, Ebay "Big DAC", and Logitech Squeezebox Duet.
Old 1st April 2013, 07:18 PM   #54
augustoriodosul is offline augustoriodosul  Brazil
augustoriodosul's Avatar
Default Decrease gain
Originally Posted by ljm_ljm View Post
MX50X2 originated in MUSICAL FIDLITY MF-XA50. Is a very distinctive, good circuit.
MX50 circuit similar, but output using low distortion CFP circuit.
The two are very stable, and very convenient production.
About MX50-SE(v7), I have a question, please:
I want to decrease the gain to 20 ~ 25 times for use in multi amplification for treble and mid range. What are the values ​​and the resistors need to change?
thank you
Old 4th September 2013, 06:34 AM   #55
larrywangsi is offline larrywangsi  United States
On MX50-SE you can see the 330 Ohm above the 2 pcs of 100 Ohm and the 10K Ohm next to 330 Ohm. Current gain is 31 times. If you want change gain to 20~25 times, you can change the 330 Ohm to 470 Ohm then the gain changed to 22 times.
Old 4th November 2013, 06:58 PM   #56
35house is offline 35house
you tell me how to set up their amps? the picture you need using the variable resistor to set the voltage 550mV? I did that but little bass in the sound has to turn the equalizer in the player. Transistors may not work properly? on hearing the sound of a very high quality, but a little bass.Nutrition 47 - 0 - 47.
Old 4th November 2013, 06:59 PM   #57
you tell me how to set up their amps? the picture you need using the variable resistor to set the voltage 550mV? I did that but little bass in the sound has to turn the equalizer in the player. Transistors may not work properly? on hearing the sound of a very high quality, but a little bass. Nutrition 47 - 0 - 47
Old 12th March 2014, 07:20 AM   #58
ljm_ljm is offline ljm_ljm  China
I have to update the data.
Old 16th July 2014, 01:31 PM   #59
ivanlukic is offline ivanlukic  Serbia
Originally Posted by Buckeye View Post
Moral of the story... don't underestimate the need for on-board filter and bypass capacitors on the rails.
If you look at the original Musical Fidelity pcb that LJM posted you can see that PSU is only an inch or two away from the output transistors. With PSU so close one may not need bypass caps for absolutely stable performance. But LJM made clone board without PSU and many constructors will place PSU at greater distance from the amp board so it would be highly desirable to have bypass caps onboard near output transistors. It would probably be the easiest to place footprint for 100nF/100V SMD polyester caps on the bottom side of pcb near output transistors, if LJM decide to make some new version of the pcb.
Old 16th July 2014, 02:19 PM   #60
Originally Posted by ivanlukic View Post
................. PSU is only an inch or two away from the output transistors. With PSU so close one may not need bypass caps for absolutely stable performance.................
One certainly does need local decoupling at a distance of an inch or so.
That inch or so implies a minimum flow and return circuit length of >50.8mm
That is enormous.
regards Andrew T.
Sent from my desktop computer using a keyboard
I tried the ebay MX50 DIY Kit, Class AB 100W+100W; Worked but problem.Hide this!Advertise here!
EOS 12V 100W SMPS Ebay UK bargain sharpi31 Parts 0 22nd September 2010 04:45 PM
+/-12V 5A, 100W filterless class D newvirus2008 Class D 20 13th September 2010 02:04 PM
UK EBAY - 100W Marshall / Fender Clone Transformer Set poynton Instruments and Amps 1 19th January 2010 07:51 AM
Best kit for 2 ohm sub, 100W+? internationalmanofmystery Solid State 3 6th September 2009 08:10 PM
Evolve Amps 100W+100W Stuff 4 Sale WALTER BURKHARD Swap Meet 4 8th June 2005 10:57 AM
Copyright ©1999-2017 diyAudio
